Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 10 Discussion
Old 04-01-2017, 04:21 AM
rantanplan rantanplan is offline
Default NUGEN HALO upmix crashes PT 10 HD
Hi there,
I downloaded the HALO upmix plugin demo to try with my PT 10 HD on OS X 10.8.5. But sadly PT crashes when I try to insert the plugin on a track. The same happens with the Audio Suite variant.
I tried both flavors AAX and RTAS without success. I also tried with both the TDM and the CoreAudio engine. Even the AU version crashes another DAW (Harrison Mixbus) on the same system. So it seams not to be a PT issue.
The point is that NUGEN can not reproduce the issue.
Is someone able to use the plugin successfully on the same system constellation: PT 10 HD on 10.8.5?
Thanks,
Till
Old 06-16-2017, 11:10 AM
Default Re: NUGEN HALO upmix crashes PT 10 HD
This problem has been solved.
With the help of Nugen support and a lot of testing we discovered that the crashes were caused by a case sensitive system drive!
Workaround:
  1. Open Terminal (Applications/Utilities/Terminal)
  2. Type "cd ~/Library" (without the quotation marks)
  3. Press Enter
  4. Type "mkdir preferences" (again without the quotation marks)
Moving Nugen AB Assit to a different insert slot crashes Pro Tools DJ Hellfire Pro Tools 12 Discussion 11 09-01-2017 01:22 AM
FS : NUGEN Visualizer 2 + NUGEN Audio SEQ-S Gemylon Buy & Sell 0 08-09-2015 06:01 AM
Metric Halo - Halo Verb ? Karel Noon VENUE Live Sound Systems 8 07-15-2015 10:41 PM
Upmix test jbelliston Post - Surround - Video 11 08-10-2014 11:53 PM
Penteo 4 Pro - 5.1 upmix MIKEROPHONICS Post - Surround - Video 79 05-21-2014 09:30 AM
