Old 02-03-2017, 07:06 PM
Chief Technician's Avatar
Post Re: HELP ! Big problem since i update 9.0.6
Originally Posted by hansbarkes View Post
I tried to make an install with the universal snow leopard DVD, and it doesn't work.
My mac do not boot on this holly disk.
Any idea ?
Use the Mac operating system that came with your Mac, or a compatible newer version
According to EveryMac, the minimum OS X v10.6.3 build you can use is 10D2094. The release date of your MacBook Pro and OS X v10.6.3 are within weeks of each other. What could have happened is that Apple released a machine-specific build of OS X v10.6.3 for your MacBook Pro. In this case, you would need the gray discs (that you have lost) in order to install OS X v10.6.3.
Alternatively, you could startup the computer in Target Disk Mode (hold T at startup) and use a FireWire cable to connect it to another Mac that is capable of starting up from the OS X v10.6.3 DVD. This would allow you to install the OS on your MacBook Pro.
I found Pro Tools v9.0.6 to be problematic with OS X v10.6.8. My suggestion would be to use Pro Tools v9.0.5 with OS X v10.6.8.
Old 02-05-2017, 07:55 AM
hansbarkes hansbarkes is offline
Default Re: HELP ! Big problem since i update 9.0.6
I re-installed a clean system (10.6.8) on my macbookpro and PT 9.05.
All is allright now.
I don't move anything anymore...
THX everybody
[IMG] code is Off
Update problem costa Pro Tools Software (Mac) 0 08-28-2011 01:17 AM
ProFire 2626 problem on MAC and Update problem razzor Pro Tools M-Powered (Mac) 4 04-22-2010 09:09 AM
update problem rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-24-2007 05:21 AM
Update to 5.1.1 problem DonMR Pro Tools TDM Systems (Mac) 2 11-07-2001 02:41 PM
PT LE5.1 - 5.1.1 update problem dnerd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-04-2001 07:55 AM
