Old 01-02-2017, 07:21 AM
estokes1958 estokes1958 is offline
Default Issues with Sonivox instruments?
Has anyone had performance issues with Sonivox AAX virtual instruments in instrument tracks?
I am running PT 12.5.2 on Windows 8.1 and having problems with two Sonivox AAX VIs on instrument tracks ("Wobble 2" and "Taylor Acoustic Guitar"). Since these are the only Sonivox VI's I have, I might assume that the problem is with all Sonivox VIs?
I notice that these virtual instruments do not reliably produce audio output on instrument tracks. I have found a few tedious workarounds. For example, if the MIDI clip is selected, then audio output will be produced. Or (in recording) if a blank MIDI clip is put down first, then audio output will be produced in "MIDI merge" mode.
Old 01-02-2017, 07:55 AM
Default Re: Issues with Sonivox instruments?
Solved: Turn off the "loop play" function and Sonivox instruments function normally.
Old 01-02-2017, 02:19 PM
Benoni's Avatar
Benoni Benoni is offline
Thanks for sharing
Brian
Windows 10 Pro 64 Bit
Pro Tools 12 | Eleven Rack + ERXP
Youtube Channel - BenoniStudio
Free Eleven Rack Tutorials, Rigs, and more
@BenoniStudio
Instagram
Old 01-02-2017, 02:31 PM
amagras amagras is offline
I have to try this asap with he strings, i only get audio when the midi note ends.
Dell XPS 8700, Windows 10, NI Komplete Audio 6, Pro Tools 12
andreimartinezagras.webs.com
Old 01-06-2017, 11:51 AM
YYR123's Avatar
YYR123 YYR123 is online now
Yes same issues with the Orchestral Companion plugs i bought the other day.
VI outputs sound fine with the transport not running.....with the transport running either recording or simple playback (recording input engaged) not producing sound correctly.
I emailed their support.....spoiler alert....was not impressed with them. (but i like the plugin, sounds great)
Hi J,
Thank you for reaching out to us. I appreciate the opportunity to assist you!
If you have additional questions or concerns, or if the information we provided today does not help completely resolve your inquiry, please let me know!
I'm sorry to hear that you are experiencing this issue. It seems like the Sonivox plug-in is working pretty smoothly, as it is generating sounds through Protools.
As for the playback. It sounds to me like it may be something going on with Protools, and my recommendation would be to contact Avid for further support.
For additional assistance, or to re-open your case, just respond to this email with your case number 1130225 in the subject line. I'll be glad to help!
Best Regards,
XXXX XXXXX
Technical Support & Return Authorizations Specialist
inMusic Brands
AIR | Akai Professional | Alesis | Alto Professional | Denon DJ | Denon Professional | ION Audio | M-Audio | Marantz Professional | Marq Lighting | MixMeister | Numark | Rane | SONiVOX
Daniel
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Jetson
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Jefferson
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Clinton
Old 04-08-2017, 02:18 PM
Micks_Mix Micks_Mix is offline
Same problem here, thanks for the workaround!
Seems to be a simple issue, no fix for months now...
Pro Tools|HDX, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 12.7.1 w/ HEAT option, Mac Pro 5.1, 24 GB RAM, OS 10.9.5
Old 04-08-2017, 04:07 PM
I got pretty much the same response. Also, someone shared the loop play workaround here in another thread months ago, it works but still this is a serious bug that happen on all Sonivox VIs I've tried (and won't buy for sure).
Old 04-08-2017, 04:48 PM
YYR123's Avatar
Yes it's a bummer, but what's worse is I like the sounds !!!
So I'm stuck with the bug, but at least I like the product....
Daniel
Old 04-08-2017, 04:53 PM
I love the sound of the strings.
Old 06-23-2017, 11:38 PM
Tomás Mulcahy Tomás Mulcahy is offline
Happy to delete 10GB of Sonivox strings from my drive. Cannot work without loop play. The built in eq doesn't work properly either- reminds me of the eq in Cubase VST 1.0! Very nice sounding strings but unusable in Pro Tools. I have plenty of other libraries that sound just as good.
Sonivox Premier Upgrade Justin1524 AAX Plug-ins 4 12-18-2016 09:56 AM
SONiVOX Wobble help!? Friday0089 Virtual Instruments 7 01-24-2015 08:38 AM
Sonivox Plug ins and Pro Tools MP 9 Dohara Pro Tools M-Powered (Mac) 0 05-10-2012 11:44 AM
