Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 12-11-2016, 09:04 PM
vudoo vudoo is offline
Default Cubase 9 and S6 V3.5 bug
Just upgraded to CB pro 9 and having all sorts of problem with my S6 V3.5.
It works fine with CB 8.5. Any idea when this will be fixed ?
Old 12-12-2016, 06:56 AM
Brandonx1 Brandonx1 is offline
Default Re: Cubase 9 and S6 V3.5 bug
Isn't this a Steinberg.issue, not s6? Steinberg is the one implementing the eucon protocol.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 12-13-2016, 11:35 AM
EddieJones's Avatar
Yes this would be a Steinberg issue. What are you seeing that is wrong ?
Old 12-14-2016, 12:13 PM
I already contacted Steinberg...
Anyways, here's the problem i'm having:
I have the latest (v 3.5) WScontrol/Eucon installed.
I'm using a MacPro 6.1, 12 cores, 64 GB ram, El Captain 10.11.6. The S6 works great with Pro Tools 12.6.1, Logic X 10.2.4, Cubase Pro 8.5.
But under Cubase 9, i'm getting all kinds of strange behaviour:
1- The two small LCDs on the Master module do not work (the two small LCDs is not lit)
2- The two small LCDs on the Automation module do not work (the two small LCDs is not lit)
3- Lots of erratic behaviours, the bar/beats/timecode counter stops working, faders snaps back to zero no matter what i do, transport stops working....these behaviours happen after few minutes of use and changing between different screens (mixer, main window etc) in CB9
Old 12-14-2016, 02:19 PM
EddieJones's Avatar
The first 2 are simply that there are no appsets for Cubase 9 yet. The easiest fix is to go to the Softkey editor and load the Cubase 8 appset.
We are getting our cubase 9 installation going and will look at the others but you should also report to Steinberg. they have a S6 so can test and fix.
Eddie
Old 12-15-2016, 12:18 PM
Yes, i already sent all these info to Sternberg.
Btw, where can i find the Softkey Editor and Cubase 8 applet ?
Thanks Eddie...
Old 12-15-2016, 12:57 PM
EddieJones's Avatar
On the Master Module go to the settings pages and Select Softkeys tab.
Old 12-15-2016, 01:35 PM
Unfortunately, it does not work. I get an error message when trying to load the S6_Cubase 8 Appsets...''Attempted to load invalid applet or applet that does not match the focused app type...''
Old 12-15-2016, 02:29 PM
EddieJones's Avatar
Here's a Cubase 9 Appset we made in the meantime. I had to rename the extension to pdf to upload it so change the name back to S6_Cubase9.xml
Stick it here on the Master Module C:\Program Files\Avid\S6\Appsets\Factory Default
Disclaimer: We are still waiting on our copy of 9 from Steinberg so this is not tested. It wont do any harm to try though.
Old 12-15-2016, 07:13 PM
Wow, thanks a lot Eddie. I will give it a try tomorrow and report back.
Thx again!
Cubase SX3 abd Cubase 4 LE STILL no MIDI! Shiver1 MIDI 2 12-02-2008 10:30 AM
PT and Cubase? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-10-2007 01:48 AM
PT and cubase pilarek MIDI 0 07-19-2005 02:11 PM
M Box and Cubase on PC thin ice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-06-2004 02:30 AM
Cubase with Digi001, where to set latency on Cubase Eiko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-17-2000 08:28 AM
