Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 9 Discussion
Old 11-25-2016, 04:20 AM
LukeFromBerlin LukeFromBerlin is offline
Default How to trim multiple Regions on GRID at once ?
I am sure there is a simple way, but I just have not found it yet... neither in the forum nor the manual nor by try & error...
I would like to trim MULTIPLE regions at once. Onto grid. But if I choose more than one region (i.e. using the "+ grabber tool") and then try trimming using the trimmer tool, only the one region my mouse is on changes it's size. In all other daw's I work with (Logic, Live, Nuendo...) ALL regions would change their size then, some at least when holding shift. Of course I tried the same procedure while holding shift, but still PT de-selects all other regions the moment I move the bundary of the one.
I specifically need this, as after using "strip silence" on imported stem tracks (music) I would like the boundaries to be on the beat. In grid mode, when I trim, the region is spot on then ... but only the ONE region, not all. And sometimes I have 10 or 20 regions on that track. Trimming each region by hand (what I do now) seems way to much hassle and I am sure there is a much more clever approach ... ?
Alternatively, if strip silence would have a "grid mode", not only a ms-time-default, that would be even better... then it would be done in one step !
I am still on PT 8 (for several reasons), I hope this sub-forum is still a good place for me to ask....
A new workflow would be a massive timesaver for me (and more fun to work) so thankx a lot ... !!
Soft: ProTools 8.1
OS-X 10.6.8
Hard: ProTools HD 2, PCI-e core & accel, 96 I/O, 192 digital I/O, Sync I/O (not sync HD)
Quad-Core Mac, Intel
Old 02-28-2017, 12:21 PM
joachim's Avatar
joachim joachim is offline
Default Re: How to trim multiple Regions on GRID at once ?
Yes, it is a pain, not to be able to drag multiple object-selected clip starts or ends simultaneously, except by the nudge value !
A script might help. But I am not sure, if I understood your problem correctly.
The following prerequisites for the script :
a track with dummy clips, that are all of 1 bar length,
a timeline insertion to the first start of the first dummy clip.
This works with Autohotkey on Windows, but there a scripting apps for Mac.
The BOLD stuff is the necessary code, all behind // are just remarks
Menu, tray, tip, Trim Clip Start earlier to Grid
#CommentFlag //
#if, WinActive("ahk_class DigiFloaterClass") || WinActive("ahk_class DigiAppWndClass")
// Trim Clip Start towards the next Grid Line with a Dummy Track below
// Tab first to the Start of the first Dummy Clip
^F2:: // = Ctrl + F2
send {ShiftDown}{Tab}{ShiftUp} // selects the Dummy from Start to End
send p // moves Edit Selection up to the strip-silenced Clips
WinMenuSelectItem, Pro Tools, , Edit, Trim Clip, Start to Fill Selection // fills the Clip Start to the Beginmning of the Selection, which is the Grid Line
send ü // moves Edit Selection back to Dummy Track , it is "Ü" in German, take the proper command according to your keyboard layout
send {Up} // makes an Insertion at the Beginning of the next Dummy Clip
return
A demo of the code in realtime :
https://www.dropbox.com/s/pkxmqkoozo...cript.mp4?dl=0
I do it one time slowly, then undo, then do it again quicker.
The shortcut is assigned to Ctrl F2, but can of course be assigned to whatever free shortcut.
PT 11.3.1 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 64GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 03-03-2017, 11:33 AM
joachim's Avatar
A script of this kind is smarter, works without a dummy, extends a selected clip to the left to the nearest beat :
send /
send Arrow right
send Arrow right
send 0
send Enter
[IMG] code is Off
trim/extend multiple regions chris.d Pro Tools 11 Discussion 10 09-28-2017 10:57 PM
scisors and trim multiple regions at once. Going NUTS here damasio Getting Started 13 09-25-2015 04:58 AM
Trim regions across multiple tracks? Dave Labrecque Pro Tools Software (Win) 16 08-15-2011 04:28 PM
Possible to trim or extend multiple regions at once? Mike Greene Pro Tools TDM Systems (Mac) 5 02-05-2008 02:57 AM
can you trim many regions at once? elmostephane Tips & Tricks 0 07-19-2006 03:28 AM
