Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 08-24-2015, 07:41 AM
J-S-Q J-S-Q is offline
Default Is there a track limit with this app?
Is there a track limit with Pro Tools Control?
Just tried it briefly (with Cubase) in a session with 144 tracks. It worked for a minute or two and then when I selected the 'Tracks' view, I got an error message saying "EuCon: The number of allowable channels has been exceeded" and then a crash.
Before I spend lots of time trouble shooting, it would be good to know if this app can run with very large sessions? (I never have a problem running my S3 with high track counts.)
Old 08-25-2015, 01:31 AM
Default Re: Is there a track limit with this app?
Did a bit more experimenting and it seems the problem only occurs with 'Tracks' view. With 'Mixer' view the app seems to run fine with a 100 track Cubase project (although I haven't tested it for an extended period).
BUT if you have 'Tracks' view selected, everything is fine with 36 tracks or less. As soon as you add track 37, the error message appears. The app will crash and usually Cubase will crash too.
This app is not useable for me right now unfortunately.
Would be interested to hear from any other Cubase users on this? Or Pro Tools users as well. Are you guys able to run high track counts with 'Tracks' view enabled?
Old 08-29-2015, 10:33 AM
falcowe falcowe is offline
I had a similar issue, I didn't actually do a track count, but I know the session I had open had somewhere in the 40 tracks range.
Old 08-30-2015, 04:30 PM
Were you running Cubase or Pro Tools?
Old 09-09-2015, 02:57 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Hey Guys,
We cannot get it the crash to happen with Cubase 7.5. We've been testing with 150+ tracks looping playback and going between Mixer/Tracks view.
Can you provide a bit more system info?
Thanks.
Kyle Splittgerber
Avid Product Designer
Mountain View, CA
Old 09-18-2015, 03:54 PM
Sorry it took me a few days to get back to this. I was using Cubase Pro 8, and a 65 track session would load in the mix window of the Control app but not the tracks display. I am using a MacPro (2013), Mac OS 10.10.5 16 GB of system memory. If you need more system info let me know.
Old 10-07-2015, 03:51 PM
I'm running Cubase 8 (64Bit) and Windows 8.1 (64Bit). At the time I made the tests, it would have been either version 8.0.2 or the latest version of Cubase, 8.0.3 and it would have been v1 of the iPad app. I'm also using an Avid S3.
When I get some time, I will retest with the updated v1.0.1 of the app.
Old 11-01-2015, 10:54 PM
303Dan 303Dan is offline
Did you ever figure this out? I just installed Eucon and the app and I'm seeing similar behavior with the exact same error message from Eucon.
Dan
Old 11-09-2015, 03:05 AM
Well I finally got round to testing the new version and the situation is still the same. On adding the 37th track, I get a Cubase error message/crash when I access the tracks page on the iPad. This is with the latest versions of the app, Eucontrol and Cubase, and Win 8.1 64Bit.
Hope this is sorted out by the time the Avid Dock comes out. I own an S3 and the Dock looks pretty cool but I guess the iPad app will be a development of the current Pro Tools Control so looks like it may have issues running with Cubase.
If anyone's got any troubleshooting suggestions, would be good to hear.
Old 11-09-2015, 03:07 AM
Dan
Are you running Cubase 8?
Pro Tools Track Limit Freis968 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-03-2006 10:19 PM
20 Track limit Cayotic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 06-09-2004 08:49 AM
Track Limit pwat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 05-11-2004 05:39 AM
32 track limit? David Abraham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-25-2004 06:49 AM
track limit mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-21-2002 04:41 PM
