Old 07-22-2015, 03:10 PM
pqlior@mac.com pqlior@mac.com is offline
Default Sync HD messing up!
I have a SyncHD (blue) feeding a Big ben. Big ben set to accept WC and sends that to (3) 192's WC in. Had it this way for years now with Sync IO. Now with the HD- I set it to internal, 96K, 30FPS (non-drop) and set the 192's to accept WC. It works great. The second I enable the SyncHD in the peripherals menu, it reverts to loop sync and says 96K, but the big ben shows it's getting 70.90
By the time I go into my session @96k the 192's are all messed up.
ANYONE?!
Lior
HD Native * PT 12.8.1 * OS X 10.12.5 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble 6.0.16.778 * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 3.7.0 *
Old 07-22-2015, 05:14 PM
Default Re: Sync HD messing up!
Seems to be resolved- had to deselect 'enable dub window' Not sure why that was causing all this chaos, but here we are!
Lior
Old 07-23-2015, 02:16 PM
Default Re: Sync HD messing up! [SOLVED]
Ok- I was to quick to cheer!
This is what's happening now-
The SyncHD is set to internal (PT is off) 96k,30fps feeding the Big Ben.
I launch pro tools. Set up H/W to accept WC on all (3) 192's.
Open session, lock to sync- perfect.
When I quit protools- SyncHD ALWAYS reverts back to loop sync and messes the whole setup again.
How do I get to stay in internal when in standalone mode?? (after quitting PT)
Lior
Old 07-23-2015, 06:37 PM
Chief Technician's Avatar
Arrow Re: Sync HD messing up! [SOLVED]
You don't. I have complained about this for years. After you quit Pro Tools, you have to manually press the buttons on the chassis to get it back into internal/vso mode.
Old 06-28-2017, 10:20 AM
Not sure why this says RESOLVED. It's not. This is still going on after all these years. Avid? Users?
Please help!
Lior
Old 06-28-2017, 01:31 PM
Southsidemusic's Avatar
I removed the solved text so please dont start new threads for the same issue.
Thanks
Best Regards
Christopher
South Side Music Group
WEBHOME
SOUTHSIDEPUB
#ninjakittenshatecrunchyleaves
Eagles may soar, but weasels don't get sucked into jet engines
Reaper Rewire and Pro Tools sync solved soybalm Pro Tools Software (Win) 5 12-22-2015 02:03 PM
Delay Compensation Messing Up Video Sync..? Jon_Atkinson Post - Surround - Video 21 06-07-2015 08:46 AM
Radar II sync to Pro Tools ***Solved*** GuyPicks Pro Tools TDM Systems (Mac) 5 06-13-2008 09:04 AM
Sync I/O messing with 192's dig output w/workspace Gio Mix Pro Tools TDM Systems (Mac) 3 01-31-2007 10:21 AM
