Old 02-06-2014, 08:19 PM
kingofallwookies kingofallwookies is offline
Default Drawn MIDI note length only staccato notes, regardless of note length
I am drawing MIDI notes into an instrument track in PT 11.1.2 and no mater how long I draw the note duration, my MIDI meter peaks, then recedes.
I am using the track to ReWire into the most current version of Reason, which is similarly reading only a staccato blast, then the "NOTE ON" light on the selected instrument disappears.
So - How to I get PT11 to read and send a correct note length value from the note I've drawn.
Thank you!!
Old 02-07-2014, 06:31 AM
Default Re: Drawn MIDI note length only staccato notes, regardless of note length
Thank you!!
Try something simple first - instead of rewiring into Reason insert a regular vi on the Instrument track - say one of the stock Avid ones but not a drum vi. Pick a sound that sustains. Then start drawing in your MIDI notes on the Instrument track and see what happens. That will at least tell you your technique and system are working.
For future help: please include info about your system when posting questions (computer, operating system, etc.) as this will help in diagnosing things.
Jack
QAPLA!
Old 02-07-2014, 08:10 AM
ChuckS ChuckS is offline
I believe the MIDI Meter just registers the Note On Velocity. Maybe someone else can confirm.
PT 2018.1 DP 9.51 VEP 6.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1709)
PT 2018.1 DP 9.51 VEP 6.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.3
MIDI note length in ticks jteipen Pro Tools 10 1 03-26-2013 09:12 PM
What does the length of a midi cymbal note really do? DC-Choppah Tips & Tricks 9 01-07-2013 07:03 PM
MIDI playback is only staccato note attack moltenguava 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2011 12:06 AM
Please help, Midi note length... Patill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-31-2007 03:59 PM
seperating velocity and note length? is it possible? tritonkorg MIDI 3 04-24-2007 11:09 PM
