Old 09-23-2013, 04:03 PM
mesaone mesaone is offline
Default Re: Do you have to have a 7200 rpm hard drive to run Pro Tools 10?
Originally Posted by Emcha_audio View Post
Well there is 10 000 and 16 000 rpm beside flash and ssd drives
They double as ambient noise generators and space heaters.
Old 09-23-2013, 07:00 PM
sunburst79 sunburst79 is offline
I moved my Rapters to my live rig. No ones going to hear them over a 5 piece rock band.
Its nice that the WD Black drives are fast and quiet for the studio.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 09-23-2013, 11:05 PM
Emcha_audio's Avatar
True but even then I moved my computer out of the studio a long time ago.
Manny.
#BOYCOTTTUSPRODUCTS
just not Pro tools and compatible plugins...
Old 09-24-2013, 06:01 AM
louieshowers louieshowers is offline
Do any PC's come with 7200 rpm hard drives? I will be making a choice to buy a new rig within the next 6 months. I am definitely using an SSD for C: drive though.. Maybe it is a stupid question, haven't had the need to shop around in years. Thanks!
Windows 7 64 Ultimate: SP1
PT 10.3.8
¨WHERE´S MY CHECKBOOK?¨
https://soundcloud.com/louieshowers
Old 09-24-2013, 06:28 AM
To many variables there these days. It depends on the PCs intended market. Most non entry level desktops may have a 7200 drive. In the interest of power saving however a huge number of PCs are coming with lower power "green" drives. You would just have to get the specs for the manufacturer. And surprisingly most don't list drive speed. Just capacity.
Actual workstations for HP or Dell will probably sport hi performance 7200 drives. With even faster 10-16k drives available in some cases.
Scott
Core 2 Specs Page
  #16
Old 09-24-2013, 07:21 AM
Thanks Scott. I appreciate your insight.
PT 10.3.8
  #17
Old 09-24-2013, 06:46 PM
Given most computers from the big OEMs often come with a fairly generic drive image with tons of factory bloatware installed to the C drive I'm a big advocate of actually installing a fresh version of Windows to a blank 7200 RPM drive. I'm fairly convinced that its these unoptimised drive images that often cause issues and keep some of the factory machines from running PT as smooth as they should. And its one of the reasons that the custom DIY machines do better.
That's just a hunch. I have no particular data to back that up. And if my new laptop or tower was running PT great out of the box I doubt I would reformat it. But if it was giving me issues and the hardware was known to be working with PT I'd probably start with a fresh install of Windows and only PT. If only as a troubleshooting step.
Dell and HP have both had issues where there machines blue screened after service packs. In both cases they had used drive images with registry settings and or driver for the wrong CPU manufacturer. IE the drive image was optimized for a AMD processor and the machine actually had a Intel chip. And Vica Versa.
I believe your better off installing Windows and let it install the right drivers and hardware abstraction layer etc for your actual hardware. I'm mentioning this not to derail the thread but because it sounds like you were going to go looking for a off the shelf computer. Its just something to keep in mind.
/end derailment.
Well almost.
I have seen some pretty obvious increases and decreases in boot when cloning from 5400 to 7200 and vica versa. Bottom line is I won't buy a 5400 RPM drive unless its the only available choice. They are S L O W.
Scott
Core 2 Specs Page
  #18
Old 09-25-2013, 06:15 PM
/end derailment.
Well almost.
Agreed. I also did what you mentioned about a fresh install of windows 7 on my current laptop as well as the fact that I replaced the internal hard drive with an SSD... and it flies with Protools 10 especially considering that it only has a dual core processor and a 5400 rpm external WD black audio drive.
I am more than happy with the amount of years and performance this Toshiba Satellite has given me. I bought it in 2007-08. I just don't want to be limited with the amount of VI's and heavy plugins on my future sessions, so for those reasons, I know that I will be making a purchase (most likely toshiba again) within the year.
So as far as my C: drive, it will definitely be an SSD and then I will have to look into making sure they offer a 7200 or greater additional Hard Drive for my audio. I actually bought my rig directly from Toshiba and got to choose the specs. This time I know exactly what I need, and have another 7 or so years of Protools troubleshooting experience. I am pretty confident that it will work out great. I just was wondering if these 7200 rpm drives are common requests these days for laptops?
-peace and thanks
-Lou
PT 10.3.8
  #19
Old 09-25-2013, 06:16 PM
ianbee ianbee is offline
I've been using a 5400 rpm external drive for over a year now and have not had one issue with it yet... Maybe I'm just lucky though...
  #20
Old 09-25-2013, 06:26 PM
me too. a WD passport external black
PT 10.3.8
Is this 7200 rpm external hard drive ReynaldoPena Pro Tools Software (Win) 1 11-20-2012 07:54 AM
2.5" 7200 hard drive ThaRhythm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-07-2010 11:54 AM
7200 rpm vs 10000 rpm hard drive akewldewd Storage Subsystems 2 09-26-2010 08:55 AM
FW Hard Drive Help? 7200 Fantom drive not working 72reissue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-10-2005 02:28 PM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
