Old 02-15-2011, 12:24 PM
SNAPPER SNAPPER is offline
Default song will not open, could not complete the open session commandbecause...while transl
song will not open, could not complete the open session command because...while translating tracks
song loading stops at creating main mixer spdif L-R
Just upgraded to PT9, worked fine in PT8.
many of my other songs open fine, just this one has a problem.
weeks of work went into this song
help me
Old 02-15-2011, 12:43 PM
mix109 mix109 is offline
Default Re: song will not open, could not complete the open session commandbecause...while tr
Maybe you could try using a different audio card/engine,-holding the(n) key-while PT boots?
Old 02-15-2011, 02:09 PM
formfunction formfunction is offline
help me
Its probably a corrupt session. Check the manual on "import session data". do that, excluding the tracks using the path spdf, and rebuild those after import. You should be fine. ff
Old 02-10-2017, 06:37 PM
stereoman stereoman is offline
I get something similar but I don't think it's a corrupted session i've had a few of them in the past, this is different I get this all the time in Protools 10 but as soon as I reboot and reload the session it works, i'm using an Mbox 3 in windows 10 x64 i'm thinking it's avid drivers that's the problem, I also get dropouts in windows when the sound just stops but if I changed the playback sample rate my interface starts working again. Only advice I can give is reboot your machine, it's annoying but it always fixes it for me.
Old 02-10-2017, 11:34 PM
So I just figured out why this is happening, it's due to a file ownership problem in Windows 10 the way to fix it is to install Take Ownership option you can find details on how to do that here
http://www.howtogeek.com/howto/windo...menu-in-vista/
it says it's for windows vista but it works for windows 7 and windows 10 as well, just follow the guide and install it once it's installed open your session folder and right click the protools file you want to open then select take ownership, after that your file should open without issue.
Old 02-11-2017, 10:00 AM
The Weed's Avatar
The Weed The Weed is offline
On Windows make sure your onboard soundcard is the default for Windows sounds/audio and leave the Mbox 3 only for Pro Tools. This may not be your issue, but it will solve other issues that may crop up.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 02-11-2017, 11:32 AM
So I just figured out why this is happening, it's due to a file ownership problem in Windows the way to fix it is to install Take Ownership option you can find details on how to do that here
[IMG] code is Off
Cannot open PT9 Session in PT10 - ""could not complete the open sessions command..." median Pro Tools 10 5 10-01-2013 11:14 AM
Could not complete the Open Session... Carpedrum Pro Tools Software (Mac) 0 09-14-2011 02:31 PM
Could not complete the Open Session? nmeisyou Pro Tools M-Powered (Win) 4 09-15-2010 04:12 PM
.. Could not complete "Open Session.." shtik Pro Tools TDM Systems (Mac) 2 06-08-2007 08:28 AM
Could not complete Open Session... bearease Post - Surround - Video 3 10-13-2006 09:08 AM
