Old 07-11-2009, 09:05 AM
RussUK RussUK is offline
Thumbs up DB33 Organ Part 1 Video
Russ starts a new series giving users the background and features so that users can get the best from this plugin. In this session he goes over the history of the Hammond and how it created the sound.
http://airvirtualinstruments.blogspo...t-1-video.html
I work with amazing people who do amazing things.
Old 09-04-2009, 12:30 PM
Zing_UK Zing_UK is offline
Default Re: DB33 Organ Part 1 Video
And its a brilliant piece of work, Russ - many thanks
Old 06-27-2017, 08:45 PM
EarthGuest EarthGuest is offline
I am trying to find out if I can program the Leslie speaker like you would do volume or whatever. The change from slow rotary speaker to fast is one of the most impressive effects of a Hammond B3. Everything about the DB33 is so realistic. However, I find no way to automate the process of the Leslie going from slow to fast within a specific measure or measures of a recording. Is there a way? Or is my only choice just on or off? Thanks!
Old 06-27-2017, 11:51 PM
Top Jimmy's Avatar
The rotor automation parameter is known as "Spd". You can enable this parameter and write all the automation changes you want. You can also map a controller to the rotor function.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.2.
Pro Tools HD 12.8.1, Mbox3, MOTU PCI-424 w/ 2408mkII & 1224 (Mac)
Pro Tools 11.3.2, Mbox2, Focusrite Scarlett 18I8 (Win 7)
Old 06-28-2017, 04:13 AM
Generally a Leslie is only 3 speeds - fast (aka tremolo) slow (chorale) and off (stopped). In a vi that's all you have access to. A lot of Hammond drawbar organ emulations have the speed controlled by the modulation wheel on a synth. That's one thing to look at for speed change.
If one is using an external Leslie effect like PSP's L'otary you can program the speed control via any number of MIDI cc's. The plugin has both a button to switch between the discrete speeds and there's also a programmable lever to go continously from slow to fast and back again.
Jack
QAPLA!
Video of CPU usage WAY too high - part II propower Pro Tools 11 Discussion 64 06-13-2015 01:51 PM
DB33 Organ Part 2 Video RussUK Virtual Instruments 0 07-12-2009 09:46 AM
Video - Structure Sampling 101 Part 3 RussUK Virtual Instruments 1 04-19-2009 07:49 PM
Video - Structure Sampling 101 Part 2 RussUK Virtual Instruments 0 04-18-2009 03:35 AM
Strike -Accelerated Video Part 2? JCWarrior Virtual Instruments 13 10-27-2007 12:08 PM
