Old 03-10-2008, 06:49 AM
riggi riggi is offline
Default EXPORT MIDI from Stryke NOTE FOR NOTE...
Here's how to do it... Plain and Easy.
1. Get STRYKE on screen
2. Play a pattern from start to where you want to stop.
3. Select EXPORT MIDI and drag it onto the EDIT window where there are NO TRACKS set. Usually at the bottom of the edit window.
4. A window will open up asking if you want to make a new track. Select NEW TRACK, and answer any of the options to your liking from this same window.
5. It will create 2,3,4,5,etc... NEW TRACKS that have individual STRYKE tracks labelled with their corresponding MIDI CHANNEL labeled as well, in the track name. <TOO COOL!
6. Select the corresponding STRYKE midi channel that matches the track name label. <TOO EASY!
7. Press play and watch the INDIVIDUAL NOTES play the corresponding STRYKE instrument. <EVEN COOLER!
8. Edit these notes as you wish in the midi domain.
9. Go back to STRYKE AND play the next pattern from start to where you want to stop.
10. Continue from Step 3.
BONUS NOTES: if you drag the next patterns onto NEW TRACKS you can always cut and paste the midi information from these new tracks to the existing tracks you set up the first time you started EXPORT MIDI from STRYKE. This will keep the edit window neat and clutterfree. <YOU'LL LOVE THIS WHEN YOUR PATTERN PROGRAMMING GETS INTENSE.
ENJOY!
STRYKE IS the best drum machine out there!!!!
Riggi.
Old 03-10-2008, 07:32 PM
77pro 77pro is offline
Default Re: EXPORT MIDI from Stryke NOTE FOR NOTE...
Gotta' go with riggi on this one.....it works pretty slick. Perhaps #2 is causing confusion..??... you actually play the patterns with the keyboard at the bottom of the main window (in Strike, not protools) and then stop with the red 'key'...that's it. Then grab the 'midi export' button and drag into the editor window.
There seems to be a lot of confusion regarding this function......it's actually very simple
003r/i7-930/LE 8.0.1 cs2 on xp
Drawn MIDI note length only staccato notes, regardless of note length kingofallwookies Pro Tools 11 2 02-07-2014 07:10 AM
Midi 101 really missing? Set high note/low note on track's input robinsonsdca Pro Tools Software (Mac) 4 11-10-2011 01:23 PM
Midi export creating note overlaps + gaps tombliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-18-2010 10:13 AM
"wait for note" misses first note? eric105 MIDI 8 12-19-2006 03:39 PM
Pro-Tools Note-Event (Note-off Velocity?) xytsrm Pro Tools M-Powered (Win) 2 01-10-2006 08:02 PM
