Old 12-30-2007, 10:14 PM
SimonORorke SimonORorke is offline
Default Cannot save plug-in settings to Root Settings folder
Using Pro Tools M-Powered 7.3, I get the following error message or similar when I click the Save button on the Save Effect Settings As dialogue box when attempting to save plug-in settings (having opened the dialogue box by clicking Save Settings As from the Settings menu on a plug-in window):
Settings can only be saved to the "Click" folder inside the "Root Settings" folder or inside the working session's "plug-in Settings" folder, or sub-folders of these folders.
I am trying to save the settings to the plug-in's folder (in this case the "Click" folder) inside the "Root Settings" folder. That is the initial folder when the Save Effect Settings As dialogue box is shown and I have made no attempt to change it.
In the case of the specific error message above, I was attempting to save settings for the Click plug-in. But I got the same problem when attempting to save settings for the Maxim plug-in. So the problem does not appear to be specific to a particular plug-in.
I can save settings to the plug-in's folder inside the working session's "plug-in Settings" folder.
Old 01-18-2008, 08:38 PM
Default Re: Cannot save plug-in settings to Root Settings folder
Having just switched from M-Audio to Digidesign hardware, I am now using a different version of Pro Tools: Pro Tools LE 7.4cs2. I do not get the problem with my new version. So it really does look like a bug in a specific version or versions of Pro Tools.
If anyone else gets the same problem, clearly switching from M-Audio to Digidesign hardware would be a bit drastic just to solve this problem! And it might not be either necessary or sufficient. My advice would be to try a later version of Pro Tools M-Powered. Assuming you are using Pro Tools M-Powered 7.3, you have a few options. You could try the latest free update, which at time of writing is Pro Tools M-Powered 7.3.1cs5 (http://www.digidesign.com/index.cfm?...&categoryid=36). Or you could pay for an upgrade to Pro Tools M-Powered 7.4 (or you could qualify for a free upgrade if you bought 7.3 recently). You would then have the option of trying the latest free update, which at time of writing is Pro Tools M-Powered 7.4cs2 (http://www.digidesign.com/index.cfm?...&categoryid=36).
Plugin Preset Save - Can't locate settings folder SamboBing Pro Tools 11 4 06-23-2013 04:01 PM
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
Unable to save session copies w/ Root Settings Folder nuancerec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-03-2011 02:05 PM
Plugin "Set Root Settings Folder" PROBLEM dee dee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-09-2008 09:46 PM
Plug-In Settings root folder problem TJS Pro Tools TDM Systems (Win) 1 06-12-2008 04:03 AM
