Avid @ NAMM 2018
Old 03-01-2007, 10:37 PM
mmf78 mmf78 is offline
Default Memory Location
Whenever I select different memory locations when mixing (ie., check guitars, bass, drums, etc, any) any loop i have playing will stop and be deselected. Is there anything I am missing that will solve this?
I want to be able to move from the "Drums" memory location to the "Guitars" memory location and have the loop still play.
Thanks,
Michael
MacBook Pro (10.6.3)
2.8 Ghz Intel Duo Core
4GB Ram
Mbox2
PT9
Old 03-01-2007, 10:49 PM
Shawn Simpson Shawn Simpson is offline
Default Re: Memory Location
You need to make sure the time properties of the memory location is set to 'none'. It sounds like you're leaving it set to marker or selection.
Old 03-02-2007, 12:04 AM
A work around for 7.3 is to use Dymanic Transport and the Big Counter for the Mix window.
filosofem
Aaron Mulqueen - 001 HD Native
Old 03-02-2007, 02:15 PM
I'll try that. Thanks.
And I have trouble with 7.3 and BFD so I am on 7.1.1 for now until it is fixed.
4GB Ram
Mbox2
PT9
Looking for Memory Location Timesaver in P.T. 8.0.4 FrankCan The Drum Room 5 09-12-2013 10:12 PM
Memory Location Combination syra Pro Tools TDM Systems (Mac) 7 04-14-2011 12:41 PM
Memory Location Question tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-02-2009 05:50 PM
Memory Location Assistance xianny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-27-2005 10:39 AM
6.1 bug: Can't add memory location tal herzberg Pro Tools TDM Systems (Mac) 1 07-31-2003 01:01 AM
