Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 9 Discussion
Old 02-26-2013, 08:30 PM
kessles79 kessles79 is offline
Default Do I need a microphone amplifier when I use mbox
hi guys, I am a starter, and just wonder if I need connect my mic to amicrophone amplifier, when to my mbox? thanks a lot!
Old 02-26-2013, 08:48 PM
Default Re: Do I need a microphone amplifier when I use mbox
The Mbox'es have built in mic premps (aka pre-amplifiers, what you mean when you say amplifier), different numbers depending on the model. What exact model Mbox do you have? 1st, 2nd or 3rd generation? Mbox, Mbox Mini or Mbox Pro? Microphone inputs are all clearly explained in the product manuals, which are all on Avid's web site.
Old 02-26-2013, 08:53 PM
Good advice above. The stock preamp on the Mbox is totally fine for you to get started on. Skill and experience will get you a lot farther than some expensive mic preamp
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 02-27-2013, 07:32 PM
My device is Mbox2 Mini
Old 02-27-2013, 08:28 PM
Ok, so your Input 1 is either Mic/Line/DI or Input 2 is Line/DI. If you have a single microphone just plug it into the Input 1 XLR and select the Mic input and adjust the preamp gain for best sound. If you need a second mic you will need to use an outboard Mic preamp. Newer Mboxes (esp. the Mbox 3 Pro have better preamps and converters but the time any of this is a serious limit to you you'll probably want a higher-end interface for lots of reasons.
Darryl
Old 02-28-2013, 07:42 PM
Thank you Darryl! Now I get it, my mbox2 mini has onboard preamp, for input 1. If I still wanna connect mic to preamp, then to Mbox2 mini input 1, will that sound differently, or cause device damage?
Old 02-28-2013, 11:49 PM
chrisdee's Avatar
chrisdee chrisdee is offline
It won't cause damage but the standard way to connect your preamp is into the Line/DI input jacks.
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 04-30-2017, 05:08 PM
lunchnotre lunchnotre is offline
yo i really need help please email me at fantaziser12@gmail.com
[IMG] code is Off
MBox 2 Input as Microphone globex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 12-20-2012 11:42 PM
Mbox 3 Pro External Headphone Amplifier Issue giltzer14 Pro Tools 9 Discussion 5 08-23-2011 02:46 PM
Simple microphone via DI on mbox? sytrusze Pro Tools M-Powered (Win) 5 12-15-2010 05:42 AM
Mbox 2 latency when using microphone. wrightyno1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-02-2008 09:50 PM
Mbox 2 + Microphone Issue globex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-30-2006 10:25 AM
