ilok auth not working
hi.
had my PT HD 7.1 mistakenly unistalled. when i re-installed it, my BF pultec eqp-1a plug in would not authorize. all my other plug ins did and work fine. when i hit the 'authorize' tab on the window that pops up during launch, the next window says it can't find the auth, and gives the # of the ilok it's looking on. the problem is the auth is on another ilok, which has other plug in auth's on it which work fine. i went to ilok and switched the auth to the ilok it says it was looking at, but i get the same response, that it can't find the auth. any ideas? thanks... |
Re: ilok auth not working
why not plug both iLoks in (just on the off chance that the license
transfer didn't take .. and sometimes they don't)? then launch PT. jeff |
Just a thought!! Sounds like you have installed the wrong version of Pultec EQP-1 for your authorisation! Chris
they are always both plugged in. i have auth's for other plug ins on each one. weird that only this one didn't take...
i thought of that, so i installed a couple versions of the pultec. none seemed to work. actually, one version came up with a full trial period, and the other came up with just the auth window, saying the trial period was over. i tried to auth each one but they didn't recognise the auth on the ilok, and for some reason only saw one of the iloks. i have 2 plugged in all the time.
is there a way to find out what version auth i have on my ilok? i can't seem to get any detailed info about the auth's at ilok.com? and, i emialed digidesign, and they have not responded at all yet... it's getting hairy now since i have some work to do on previous mixes, where i used the pultecs a bit. i don't really want to be forced to repurchase and auth... thanks... |
you were right. i had auth's for 3.0 . they are on 4.0 now. digi contacted me and sent me the new auth's for my ilok.
thanks... |
Voce Chorus/Vib iLok auth stopped working | JozMaz | Pro Tools TDM Systems (Mac) | 3 | 05-02-2012 12:02 PM |
Plugin auth weirdness - guest iLok prevents internal iLok? | Scott Helmke | VENUE Live Sound Systems | 3 | 09-07-2011 07:06 AM |
Transfer iLok auth. from old iLok to new 003 factory iLok? | lamp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-20-2007 07:05 PM |
ilok auth backwards compatibile - PT7.3 auth run 7.2? | Barnaby Bristol | Post - Surround - Video | 2 | 06-20-2007 09:30 AM |
New SonyEQ iLok auth not working with 2.31? | Detlef Brockmann | Pro Tools TDM Systems (Mac) | 5 | 11-16-2005 01:11 PM |
