Old 07-28-2005, 12:56 AM
dobby12 dobby12 is offline
Default Weird Behavior from my Mix+ rig
Hi, my Pro Tools rig just started doing something weird. I have a drum session coming in on Sunday so I was going through all sixteen channels of the snake, mic pre's, 888's, etc. to make sure everything was cool.
Well, channels 1-8 worked fine, but when I got to 9, I started getting a very nasty popping noise and no audio. I disconnected the mic pre and it was still there so at least that was working fine. Next step I ran Digitest and that showed everything passed.
I started thinking that it was either a. the interface, b. the digilink cable, or c. the actual card itself. I swapped the cable and it worked fine with either cable. I swapped interfaces and channels 1-8 worked fine on either one. I have a Mix Core, Mix Farm, and DSP Farm card so I unplugged the interface from the Mix Farm card, changed the settings, and hooked it up to the DSP card and I was still getting the same problem. So either my Mix Farm and DSP card are broken (and making the exact same noises which is not likely), or I'm missing something really obvious.
Bottom line is, as far as I can tell, the hardware is working 100% fine, but anything above A8 is only putting out a buzzing noise and no audio, and anything above A8 for inputs is making just a nasty popping sound. What gives? Any suggestions for be great. Thanks.
Old 07-28-2005, 04:49 AM
Allbaldo Allbaldo is offline
Default Re: Weird Behavior from my Mix+ rig
Check the BNC cable between the two 888's. I had a similar thing happen, and that was the fix.
Old 07-28-2005, 07:37 AM
CHRIS AIKEN CHRIS AIKEN is offline
Also reseat the tdm node cable that goes between your cards...actually reseating the cards could possibly help as well.
I'd trash all preferences after that too.
Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate
please help with this weird behavior Anibal macOS 8 05-05-2013 11:12 AM
Automation Help - Weird Behavior Daniel Sasso Pro Tools TDM Systems (Mac) 4 03-26-2010 10:32 AM
BUG (7.4): Weird browser behavior Frank Kruse Post - Surround - Video 0 11-12-2007 08:47 AM
weird region behavior 372cat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-15-2007 10:01 AM
Weird links behavior Oroz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2006 10:00 PM
