Old 07-23-2001, 08:15 PM
Kenny Gioia Kenny Gioia is offline
Default Re: Enuff Q: How about some tips!!!!
Different way to make vocal up mixes.
Instead of going to volume mode and raising it their where it sometimes makes new anchor points and screws thing up.
I prefer to put the vocal in Trim/Auto write mode which pops the fader up to 0dB.
Then you raise or lower the fader 1dB as needed, then open the automation enable window and click the write to all button. That's it.
I prefer this way as it is more precise and if you use the procontrol shortcut even quicker.
Old 07-23-2001, 10:56 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Jules..Don't you think you should give Andy (how do you mix drums?)some credit about your tip? [img]images/icons/rolleyes.gif[/img]
Vedat
Check out WaveRider + Defaulter:
QuietArt.co.nz
Catchin' SYNC app
Old 07-24-2001, 01:58 AM
audiaudio audiaudio is offline
Hey Produceher,
Nice work on LFO's "Every Other Time." I really like the morphing of rock and hip hop elements with pop songwriting and vocals.
If you don't mind my asking:
(1) What do you use to compress the stereo buss? The LFO mix is real tight and focused.
(2) Also, do you mix in Pro Tools? Any favorite plugs?
Nice goin'--and thanks for the info.
[ July 24, 2001: Message edited by: audiaudio ]
 HD Accel 2 | PT 10 | Mac Pro | 5G RAM | OS 10.7 | MBP Retina | 002R
Old 07-24-2001, 07:50 PM
Marc Edwards Marc Edwards is offline
Smash it up, smash it up!!!!
Old 07-25-2001, 05:36 AM
Jules Jules is offline
"Mundoz
Jules..Don't you think you should give Andy (how do you mix drums?)some credit about your tip?"
If I repeated something already suggested I apologise for being boring, but I wont apologise for trying to be helpful!
Mundoz, there is some brown stuff on your nose, it looks kinda nasty!
[img]images/icons/shocked.gif[/img]
Jules
[ July 25, 2001: Message edited by: Jules ]
Jules
London, UK
Come hang with us here!
www.gearslutz.com
  #16
Old 07-25-2001, 06:12 AM
rodney morris rodney morris is offline
When I am working with a track that has clicks and pops that I want to remove, I zoom in to the closest view of the offending click. Then highlight the previous full cycle of clean audio on that track and then duplicate it (command + d). The duplicate cycle replaces the click or pop without you having to redraw the waveform. MOST of the time this works - depends on the length of your offending audio. [img]images/icons/smile.gif[/img]
  #17
Old 07-25-2001, 09:22 AM
bluemt bluemt is offline
Drum tracking with hybrid kit... Real snare, cymbals, hat, Drum kat for (3) toms and kick triggering samples in S2000 sampler. Record all the toms and kick as MIDI data into one track. Duplicate that track four times, rename new tracks (kick, tom1, tom2, tom3). Delete all MIDI data in each track except the drum you want. Mixing - after auditioning drum sounds, trigger samples from these tracks again and print seperate audio tracks. Excellent drum sounds while minimizing the variables of miking a full kit. No phase-related problems with tom "mics".
  #18
Old 07-25-2001, 09:44 AM
duffy duffy is offline
Insted of running drum tracks into a reverb, I send only the room mics into a verb. It sounds much more natural that way.
duffy
  #19
Old 07-25-2001, 10:06 AM
Chris R Chris R is offline
Speeding a pushy drummer: I work with a very creative (but often click oblivious) drummer. He has a tendency to end his fills early. To combat this I put PT in to grid mode, separate the next measure, copy, and paste to an unused section of the project (which I marker as "loops"). Then I switch to Slip mode and using the trim tool, I expand to get the entire 1 downbeat (usually based on the kick). I do the same with the end of the phrase (expand to the beginning of the next measure's kick). Copy the expanded region, switch back to grid mode, and paste. I then use Wave Mechanics Speed's calculator mode (samples), write down how many samples the phrase is, write down how may samples the grid is, and process the tracks so they line up to th grid. Finally I paste the processed (and on time) phrase back into the original track, trim the end of the fill, separate a 32nd note, and use speed (same method a above) again to have the fill measure (normally cymbal decay) meet the newly fixed and on time down beat.
I also use this method with Speed to create drum loops or patterns that I can pop into certain places of a song where the measures aren't being played tightly. Works well on Bass to.
Regards,
Chris Richmond : [img]images/icons/cool.gif[/img]
  #20
Old 07-25-2001, 01:27 PM
mman00 mman00 is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Produceher:
1. Whenever I have a sound that I know where I want it to end, but I'm not sure where It needs to start (For EX. Reverse crash, Reverse Reverb, Reverse Guitars.)
I place the region's start where I want it to end. Then you hit the "K" key. It shoots it back. (You must be in the mode that connects the locater with the selector) TDM system only.
<HR></BLOCKQUOTE>
Produceher, I'm not sure if you are aware, but you can spot the END of a region to the cursor position by Command-Control clicking the region.
This is a great thread. Let's keep it going.
mike
enuff is enuff...I'm sick of the crashing! hot lipps 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 08-04-2009 10:19 AM
Enuff Problems, Let's Add Some Features!!!!!! Kenny Gioia Pro Tools TDM Systems (Mac) 78 12-06-2007 01:17 PM
Is my G4 400 Good enuff or dinosaur? thumbolt68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-15-2003 08:13 PM
Is This good enuff for ProTools Digi001 gruvnaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-03-2003 04:30 AM
Enuff jibba jabba ckerian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 03-18-2002 08:00 PM
