Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 05-20-2019, 12:37 AM
clancychris clancychris is offline
Default Re: Solo In Place glitch
Thanks for responding. I had a look through the forum but didn't see anything, probably because I was looking for SIP and you're totally correct it's AFL not SIP mode, if this thread can be deleted then it should be removed. Same issue as you've mentioned
Old 05-31-2019, 07:40 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Default Solo mode AFL not working
In recording the AFL modus (solo mode) gives no audio, PFL is working. Im recording live with macbookpro laptop mojave and 2019-5 HD native thunderbolt with 4x 192 i/o. In record ready modus AFL is working. From the moment I hit record AFL stops working.
Anybody with same problem?
Johnny Hulst
Hulst Audio Engineering
MacPro (late 2013) 3ghz 8-core, 32gb Ram, 512gb SSD
1x Avid HDX & 1x UAD-2 Octo --> Sonnet Echo Express III-D
2x OWC PCI Express SSD (2TB) --> Sonnet Echo Express SE II
1x MTRX + MOM
4x 192 I/O (64 analog inputs)
1x HD Native Thunderbolt
Avid Artist Mix
http://www.hulst.nu
Old 05-31-2019, 10:23 AM
Default Re: Solo mode AFL not working
It is a known issue, discussed on DUC already in several threads, and in the 2019.5 release notes (cough, which yes I did not see either until going on about this an another thread).
(EDIT: Looks like the mods are merging threads to keep things compact here. Thanks!).
Old 06-06-2019, 11:48 AM
Badger540 Badger540 is offline
Default Re: No audio when toggling solo (AFL Mode) during playback (PT-251511)
You can get the AFL to re-appear by touching the fader associated with the solo'd channels, or of course stopping and then playing again. Annoying.
Old 06-15-2019, 02:18 PM
RobertDorn RobertDorn is offline
came across this thread. Didn't have any solo problems in 10.13.6
I'm just on 10.14.5 with pt 2019.5 , I really panicked when I found out that tracks routed to an internal bus are audible without the bus being solo'ed or in solo safe. Even worse, solo safe doesn't work. When command+clicking the solo button a fader pop appears!!?? Which even works when I raise or lower the volume.
Also had the above described bug with having to stop and hit play again to hear solo'ed tracks
I trashed preferences. Imported session data from a session with this bug in a fresh new session. (after pro tools started up again, 15 crashes upon launch and had to move and move back plugins one by one to have PT startup again. GREAT)
And it now works
ONLY UNTILL I turned on EuCon again in Perhiperals. Luckily I saved the session before doing that. Unchecked Eucon, closed session without any further saving, launched again and it seems to work
My goodness, what kind of idiots write this software.
Only the people who actually pay for it annually, so this includes me, are even bigger morons.
Apple iMac Pro 10-core 3GHz | 128GB ram | Mac OS 10.13.6 | Universal Audio Apollo X16 & X8P | Pro Tools Ultimate 2019.6
  #16
Old 06-15-2019, 07:44 PM
It was a bug discovered right before release. I suspect Avid made the right call to release with it with this documented instead of needing to hold up 2019.5 further given all the issues it addresses for most users.
  #17
Old 06-17-2019, 08:05 AM
Since it’s a paid subscription update that has taken over half a year to appear for providing Mojave compatibility, I think that I have no words to describe this level of amateurism
Verzonden vanaf mijn iPhone met Tapatalk
  #18
Old 06-17-2019, 08:11 AM
I mean... we talk about a solo function not functioning properly, not a 4 level deep eucon shortcut that's broken. What's next, releasing 2019.6 with a broken record and play button?
Even my solo safe's on some sessions are broken. Had contact with Avid support and they could reproduce it.
I mean... my god... I have no words
  #19
Old 06-26-2019, 01:28 PM
jeffro's Avatar
jeffro jeffro is offline
FYI- This issue is fixed in 2019.6 which was released today.
  #20
Old 06-26-2019, 06:48 PM
Neat, thanks Jeffro. Glad you guys spun a quick fix for the cloud storage issues and loaded this on as well.
Toggling 11R rig out in ASIO mode - solved? adamqlw Eleven Rack 3 10-06-2011 12:18 PM
AFL Solo mode and solo trim brenttrf VENUE Live Sound Systems 2 09-18-2010 12:44 AM
Toggling audio between itunes and pro tools session/DIGI 002 freedomrock69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2009 01:15 PM
toggling input on audio track causes pop: PT8 Erik Zobler Pro Tools TDM Systems (Mac) 1 12-31-2008 12:53 AM
"...not an audio playback volume" error in bounce mode blankpro Pro Tools TDM Systems (Mac) 1 12-13-2007 11:26 AM
