Old 04-20-2015, 05:31 AM
Mac007 Mac007 is offline
Default Low volume output on exported audio files (.wav, .mp3) created on ProTools 11 Softwar
When recording voice audio on my ProTools 11 Software, I get a good strong waveform (and good volume thru the headset & when playing the recorded file on ProTools). However when I export (using "bounce" command) the file to create the .wav and .mp3 files - the output gain is consistently in the -40 to -20 range, and much too weak to use. What might be causing this?
When using my free Audacity Software , both my audio recording levels (strong waveform) and outputs levels on bounced files are very good. So, I believe my difficulties are directly related to a problem on my ProTools Software.
My equipment includes: a 64-bit 2.60 GHz HP Intel Laptop, 8 GB RAM, Window 8 operating system; A Motu Ultralite mk3 preamp; a Mohave 201 FET condenser microphone; and a Glyph external hard drive for audio file storage.
Thanks for any suggestions!
Mac
Old 04-20-2015, 06:05 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Low volume output on exported audio files (.wav, .mp3) created on ProTools 11 Sof
What's your input level when tracking?
What's your plugin chain?
You do know that anything on the master fader is post fader......
Daniel
Exported and recorded audio volume is too low joelmbeck Pro Tools SE and Essential (Win) 0 07-26-2014 07:11 PM
Protools Le 8 exported audio files compatibility mat13055 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-29-2010 01:08 AM
Renaming exported audio files using copy & paste soundboy35 General Discussion 1 09-11-2004 03:25 PM
Renaming exported audio files using cut & paste soundboy35 Pro Tools TDM Systems (Mac) 1 09-07-2004 05:13 PM
[Q] Is Protools LE able to import OMF files that's exported from Logic5? hongz1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-10-2002 04:49 PM
