Old 02-22-2014, 03:27 PM
gub gub is offline
Default Reason Rewire disappeared
I am running Pro tools 10.3.8(Maverick) with Reason (re-wired). Everthing in the past has been working well.
However, I went to intruments in the PT the other day and Reason had disappeared…gone. Unable to link the two anymore.
I think it may have somthing to do installing software to run my new Novation 25sl MKII. Novation gave me some Auto mapping software so I can run PT, Reason and Ableton.
I have a feeling this may have screwed up the ability for Rewire to link PT and reason. Addtionally, when I open Abelton live i receive this message (ReWire requires OpenTransport to be installed on MacOS), not sure if that is related.
you advice on how to fix please?
Thank you
Gub
Old 02-23-2014, 12:41 PM
PatJ PatJ is offline
Default Re: Reason Rewire disappeared
I have been running PT 10.3.8 for some time, and Rewire seemed to be working just fine, until I took the plunge Friday night and updated from OSX Lion to Mavericks 10.9.1.
Now Rewire is not showing. Projects which previously had Rewire receive an error when loading reads:
Track "Aux 1" Insert A ("Waves ReWire") has been made Inactive because the plug-in is not present in the plug-ins folder.
I'm not sure which "plug-ins" folder this message is referring to.
I suspect it has something to do with the whole PT10 not being approved for use with Mavericks.
I tried reinstalling the ReWire 1.7 pkg, but no dice.
The ReWire.bundle is in the
Library>Application Support>Propellerhead Software> Rewire folder
It is also in the
Applications> Waves > ReWire folder
PatJ
MacBook Pro 8,2
OSX 10.10
UA Apollo Quad
ProTools 11
Old 02-23-2014, 02:37 PM
Alrighty,
Not quite sure why but I reinstalled Reason Essentials then Uninstalled it.
At least that's what I think I did.
I dragged the Reason Essentials folder from my Applications to the Trash.
I suspect the installing process must have shaken things up with the Rewire.
I can say that the WavesRewire is now available as a plug in.
I didn't bother to keep Reason installed as I don't use it. I just need Rewire.
PatJ
MacBook Pro 8,2
OSX 10.10
UA Apollo Quad
ProTools 11
Rewire disappeared? psdrummin macOS 18 02-19-2015 09:02 AM
Reason disappeared from Plug-Ins folder danonbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-23-2009 08:51 AM
after updating to 7.4 Reason disappeared? indoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-11-2007 07:50 AM
reason disappeared ronan73 Virtual Instruments 3 09-03-2006 05:40 AM
reason disappeared ronan73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-25-2006 02:56 AM
