Old 02-12-2014, 10:54 PM
clausiii's Avatar
clausiii clausiii is offline
Default One bug disappeared, a new one came!
Hi!
I always had problems with closing sessions, because when i did that, PT 11.1.2 quit. Nearly everytime!
Since two days this issue is gone! I did nothing (except using it)!
Good news, but now everytime i launch PT for the first time after booting the computer, PT initializes all plugins sooooo slooooooowly, just like it's the first time booting PT at all!
Any ideas?
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 02-12-2014, 11:44 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: One bug disappeared, a new one came!
I suspect you have installed some plugin that causes these troubles.
So first move all your 3rd party (non-Avid) plugins to the unused folder and see if it still keeps quitting you. If not, you have found the cause. Then keep adding 3rd party plugs back few at the time (not too many, about 3-6 plugs perhaps) and once your system begins quitting again then remove those last additions and add them back ONE at the time. Once the quitting starts again, you have found your bogus plug. Then report to the plugin vendor.
Janne
Old 02-12-2014, 11:46 PM
JFreak's Avatar
BTW,
I'm using:
MacBook Pro i7 Quad 2.6GHz 16GB RAM 1TB SSD
ProTools 11.1.2 HD
OSX 10.9.1
...and I don't see the problems you're facing. So it mustn't be OSX/PT version. Wouldn't like to think it's the interface (mine is HDN TB --> Apogee Rosetta800) so most likely it is some plugin not behaving nicely.
Janne
Old 02-13-2014, 05:41 AM
clausiii's Avatar
The problem that disappeared (quit after closing session) came after the update from 11.1.1 to 11.1.2. with nothing else installed.
The problem disappeared after installing Massey AAX plugins (they are magic !!!)
My current problem (slow initializing plugins while PT starts, every time) came after the installation of Massey plugins.
I used only the built in sound device in that case.
Maybe this one disappeares also all of the sudden...
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 02-13-2014, 10:47 PM
clausiii's Avatar
As i write this, the bug is gone...
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 02-14-2014, 10:17 AM
bradch00 bradch00 is offline
I saw the same thing with both PT 10.x and PT 11 after running the Massey plug-in wizard. PT rescanned all my plug-ins (which causes takes a few tries with PT10 due to memory consumption) PT came up quickly. Then I bought another plug-in from Massey and went through the process again... but all is good now. I'm assuming the wizard does something similar to trashing the prefs (those that involve plug-ins anyway) that causes this to happen.
Pro Tools 12, Studio One V3.x
iMac 27" 5k i7 4Ghz, 32GB RAM 1TB Flash (OS X 10.10.x)
OWC Thunderbay Mini (4TB SSD)
Interface: Antelope Audio Zen-Studio
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
Macbook Pro 8GB RAM, 512GB SSD Audio(mobile rig)
Old 02-14-2014, 10:25 AM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Hey
Same here. The Massey "Gnome" looking dude trashed the PLIST as it was in the trash can and that is the list that trashing preferences deletes aswell and makes PT rescan the entire plugin list but all is good in the hood here
After that one rescan PT starts up like ligtning again
L O V E them Massey plugins !!!
Best Regards and Happy Valentines Day Friends
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
HD on Mac disappeared stevegalante Storage Subsystems 10 08-17-2012 01:51 AM
Help: My 192 has disappeared! alanbuf macOS 1 01-03-2012 04:51 PM
Mbox 2 disappeared atchou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-29-2009 08:58 PM
Inserts Disappeared gazblake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-03-2005 07:27 AM
Digi 002 disappeared healy97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-30-2005 02:52 PM
