Old 08-12-2013, 05:25 PM
mingojr mingojr is offline
Default Audio tracks stop playing back/outputs disabled in PT 9.0.6
I'm having this problem, a user posted about it 2 years ago about Pro Tools 10 and apparently they eventually came out with a fix. Again find a work around for Pro Tools 9.0.6???? I'm guessing they've stopped supporting it and won't put out a fix!? Here's the problem below, I copied the original posters post because I'm having the same problem, hope they don't mind.
Sometimes, usually after I import some additional audio data/tracks, some audio tracks just stop playing back.
The meter will move like there is audio, but you won't hear anything. Voice shows assigned. You can solo it...no sound. Sometimes the aux track meters don't move at all.
Only two ways I've found to fix it. One is to save the session, close Pro Tools and reopen Pro Tools, then reopen the session. Then it usually happens again after 10 minutes or so.
The other way is to go to an offending track and just select the output it's assigned to and assign it again (to the same output works). This resets it and it plays again.
Any ideas.....here's the original thread.
http://duc.avid.com/showthread.php?t=311045
Audio tracks stop playing back/outputs disable rtcstudio macOS 395 07-15-2015 07:28 PM
Recorded audio is not playing back in sync with other tracks ATLracing Getting Started 4 07-08-2013 05:52 PM
Stereo Audio Tracks playing back mono rtebel macOS 2 03-25-2012 09:43 AM
Tracks Stop Playing Back 7.2.1cs1 tomhartman Pro Tools TDM Systems (Mac) 0 11-21-2006 01:36 PM
some of my vocal audio tracks not playing back...help superdood Tips & Tricks 8 03-24-2003 02:18 AM
