Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 08-14-2012, 06:51 PM
stevegalante stevegalante is offline
Default HD on Mac disappeared
Macpro 2x 3GHz Quad Core, 8Gb RAM, 4 internal disks (system disk 500 GB WD, 3x 1TB Seagate Barracuda).
Today I was consolidating a few files on a Pro Tools 8 HD session and writing the files onto an external USB drive.
I did not realize the space on the ext HD had finished, and PT returned me a weird DAE -7457 error.
After that one of the internal Barracudas all of a sudden disappeared.
When I say disappeared I mean it cannot be seen anymore in any form by Disk Utility, System Profiler, Terminal, Onyx, DiskWarrior, TechTool Pro, Data Rescue.
I swapped it to another internal bay, no way. The bays are all working, the other three disks are all working.
What has happened to this disk ???
Help please !
http://www.stevegalante.com
System details :
ProTools Native card, Ultimate 2019.5, MacPro 5,1 12 Core 3.33GHz, 64Gb RAM, Mojave 10.14.4, Lynx Aurora(n), Raven MTi
Old 08-15-2012, 06:35 AM
mix109 mix109 is offline
Default Re: HD on Mac disappeared
Steve,did you try to move the drive to an external enclosure,to' see& hear' if at least spins up?_don't think that you are able to check this inside the MacPro..
Old 08-15-2012, 06:40 AM
I'm gonna try that today... and get my fridge ready...
Anyways, by touching the disk when Mac starts it seems to have the same noise and vibrations of the other disks, but after a few seconds it seems to vibrate a little less, and the Mac booting time has become significantly longer, as if it tried to read the disk unsuccessfully. Looks like a mechanical problem, even though the coincidence with the ProTools error is weird...
System details :
Old 08-15-2012, 10:18 PM
Craig F Craig F is offline
Segate had a bad run of logic boards a few years ago 08/09ish
You may have gotten one of those
A Data Rescue House is the only why to recove if that is the problem, they take your platers and put tem in a case w/ a good logic board
for the drive it's self are you still under the 5 year warranty, Segat will swap it out but will not recover any lost data
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 08-16-2012, 05:39 AM
I tried to put it on an external case, it spins up but then nothing happens...
System details :
Old 08-16-2012, 05:43 AM
So don't you think it's something mechanical like drive heads or something ?
Anyways years ago when I had problems with WD drives I switched to Seagate, this time I'd probably go with Hitachi
System details :
Old 08-16-2012, 06:14 AM
Do you think I can try something similar by myself since I have two other identical disks ?
System details :
Old 08-16-2012, 10:33 AM
they do it in a full clean room, any dust and it could gouge the plater and/or head
WD is buying Hitachi
I don't know what it is, I just know they had a board problem and we bought 120 of them
Thank you,
Craig
Old 08-16-2012, 12:08 PM
Ok, I just tried to replace the disk's logic board with another one (since I have 3 identical disks), it seems like the disk is trying to spindle but then it stops.
Thank you for the info regarding Hitachi
System details :
Old 08-16-2012, 06:57 PM
Ok after a lot of research I found there was a firmware problem with my type of disks (7200.11); usually the data are safe and Seagate should solve the problem for free. We'll see what happens..
System details :
One bug disappeared, a new one came! clausiii Pro Tools 11 6 02-14-2014 10:25 AM
Help: My 192 has disappeared! alanbuf macOS 1 01-03-2012 04:51 PM
Mbox 2 disappeared atchou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-29-2009 08:58 PM
Inserts Disappeared gazblake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-03-2005 07:27 AM
Digi 002 disappeared healy97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-30-2005 02:52 PM
