Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
  #21
Old 04-25-2012, 02:16 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: Pro Tools HD 10.0.1 crash/freeze on GigaByte EX58-UD3R + W7 sp1 64bit Ultimate
Thanks.
I did try what you suggested. Unfortunately setting the ram timing to the values that CPUID CPU-Z shows made things worse. I had to set it back to auto. Still freezes but not as much as manual settings.
I didn't think I had to do so much teaking to get Native to work on my system. Especially since Mbox Pro and Pro Tools 10 worked so fine on the same system.
Im not especially into tweaking bios, so It would help if someone with the same system as I have posted their excact bios setting for me to copy.
Atleast the important settings.
  #22
Old 04-25-2012, 05:57 PM
Greg M Greg M is offline
chrisdee,
You really should not have to do any tweaking. Our systems are very similar. I was running an 002rack on mine before HD|Native. I really didn't do much other than unplug the 002r, and install the native core card and plug in the Omni - and it just worked. I later updated firmware and later installed PT10 when it came out.
The tweaks we are talking about should give your computer stability and speed. Can you post the settings from CPUZ from the ~600MHz column? Also, call Crucial and ask them if you can safely bump your memory voltage to 1.62 volts.
Maybe you have an incompatible plugin??? Try pulling them all into the unused plugin folder and add them back a few at a time to see if you have a problem plugin.
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.6, HD Omni, HD I/O 16x16 .
  #23
Old 04-30-2012, 12:42 AM
chrisdee's Avatar
Im not completely shure yet but It seems like Pianoteq 4 is causing the freezes Im experiencing in Pro Tools 10.x.
Updating to Pianoteq 4 version 4.0.2 and disabling multicore rendering seems to have weed out the freezes in Pro Tools.
Apparently multicore rendering in Pianoteq 4 can steal important CPU resources from Pro Tools causing it to freez/crash.
http://www.forum-pianoteq.com/viewtopic.php?id=2268
Pianoteq forum admin says this is a Pro Tools problem. Is this correct ?
  #24
Old 04-30-2012, 06:00 AM
louieshowers louieshowers is offline
CHRIS...DON"T KID YOURSELF AND SAVE YOUR EFFORTS! THIS PROGRAM IS FUNDAMENTALLY FLAWED.. Unfortunately you are at the mercy of Avid....Whenever they decide to release this fix and/or future versions that are solid and stable is when your issues will cease. I am sure that all of your other programs from other companies work swimmingly....
Windows 7 64 Ultimate: SP1
PT 10.3.8
¨WHERE´S MY CHECKBOOK?¨
https://soundcloud.com/louieshowers
  #25
Old 04-30-2012, 07:42 AM
chrisdee's Avatar
Do you mean Pianoteq or Pro Tools ?
Choosing another daw is not an option for me. Much time and money has been spent on Pro Tools and Avids hardware.
  #26
Old 04-30-2012, 08:25 PM
FWIW, without the Pianotec plugin, I am running 10.0.1 on this same mobo, i7 920 cpu and 12GB of Kingston RAM(3 sticks in the white slots for proper triple channel operation). RAM timings set manually and its working quite well here
  #27
Old 04-30-2012, 11:04 PM
Shan's Avatar
Shan Shan is offline
Pianoteq 4 is a no go with Pro Tools. It's multicore rendering causes Pro Tools to freeze. They recently disabled this feature, so you should grab Pianoteq 4.0.2 which will stop the freeze problem in PT.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
  #28
Old 05-01-2012, 12:54 AM
chrisdee's Avatar
Shane
Se my post above (#23). I already updated to 4.0.2 and it seems to work with Pro Tools now.
  #29
Old 05-09-2012, 03:26 AM
chrisdee's Avatar
For some reason Pro Tools 10.1.2 and Pianoteq 4.0.2 is acting up again!
Its the same random freezes as befor. So I guess its still a no go!
It a shame because Pianoteq 4 sounds so good.
  #30
Old 05-09-2012, 09:56 AM
Raoul23 Raoul23 is online now
Dude look at the thread (freezes) in Pro tools 10 windows forum. There is a big post there about this problem and lots of people are suffering this including me. We are all awaiting a fix for this!!!!!!!!!!!!!!!
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Update for Gigabyte GA-EX58-UD3R users albee1952 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 40 03-26-2012 12:47 AM
Gigabyte GA-EX58-UD3R and hd system dccarson Pro Tools TDM Systems (Win) 0 10-30-2011 03:45 PM
GIGABYTE GA-EX58-UD3R and HD Native + HD Omni ? chrisdee Pro Tools HDX & HD Native Systems (Win) 7 12-01-2010 05:10 PM
Pro tools HD and GIGABYTE GA-EX58-UD3R KKalampo Pro Tools TDM Systems (Win) 4 04-07-2010 11:26 PM
if you have a Gigabyte EX58-UD3R motherboard please help me. recordingguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-19-2009 09:09 PM
