Old 01-08-2002, 08:40 AM
jfk-studio jfk-studio is offline
Default Plugin count
HI
I have a question. I´m considering to buy a mixcore card and i wonder where i can find info about how many plugins you can use on each dsp-chip. I´m interested about digis own plugins and focusrite d2,d3, ampfarm, reverb-one, lexiverb and others. If anyone know please help me
Thanks in advance
Fredrik
jfk-studio@swipnet.se
[img]images/icons/smile.gif[/img]
Old 01-08-2002, 08:49 AM
SteveSZ SteveSZ is offline
Default Re: Plugin count
The best reference I've seen on chip usage is in the ProTools manual. Other than that I believe there are some old posts on this site that reference chip usage pretty thorougly. I would use a search to access some of those.
Good luck 'cos it won't be a short answer.
Old 01-08-2002, 08:51 AM
peteri peteri is offline
Some of these can be found under the specs page of the plugin details (www.digidesign.com then pro-music, plugin finder).
As mentioned above - the Digi ones are described in the manual, which you can also get from the site.
To help you on your way, if all you have is a mix core:
Mix engine - one chip,
Mixer - atleast one chip.
Therefore you have 4 chips at most for plugins
Reverb 1 one whole dsp chip per instance.
Ampfarm one whole dsp chip per instance (this sucks).
Lexiverb - I'm away from my mac, but I seem to remember 2 per chip - this is certainly the case with Megaverb (TC Works).
If you want to email me a list - if I've got them I'll start a session and note them all down for you.
Pete
Old 01-09-2002, 12:19 AM
guessi guessi is offline
what I can add is "MH channel strip": 6 instances per chip
Old 01-09-2002, 07:26 AM
AEW AEW is offline
You'll also use up chip power if you go 5.1 surround.
Auto-tune takes up one chip per track, as does echo-farm.
Mix3 looks good.
Nick
Guide/Count Plugin z1221 Virtual Instruments 2 12-12-2013 03:18 PM
HD vs Mix System plugin count Ru_C Pro Tools TDM Systems (Mac) 3 03-28-2007 04:16 PM
Confused about plugin count on PT HD Kristain Pro Tools TDM Systems (Mac) 3 10-02-2005 05:08 PM
Plugin Count at 96kh....help please psus15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-07-2004 08:42 AM
Mbox Plugin count Larryboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-21-2002 05:19 PM
