Slaving Nuendo to PT-scrub video?
Just taking a shot here.
I sequence in Nuendo 3.2.1, but use PT as my console + i/o + Video playback + mixing/stems environment. Sometimes, I need to scrub the video to find hitpoints, and am not able to do it with N3 mstr/ PT slave. When I reverse this, PT as master, I'm not able to get N3 to frame advance/retard using the +/- keys. I'm using MTC to lock the machines up. Anybody doing this, having any luck? Thanks, Mr. A.
Mac Pro 3.0 Ghz Quad Core OS 10.4.11 PT 7.3 HD3 x (5) 192D + (1) 192 w/ Analog card Big Ben MoL3 |
Re: Slaving Nuendo to PT-scrub video?
You need to enable MMC. MTC will only slave the two in play-mode.
frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Yes, MMC. My mistake in not saying that in my initial post.
MMC is not allowing me to frame advance the slave from the master controls. Thanks, JVT
The only hint I can give you (due to the lack of nuendo) is that I slave a bonsaidrive via MMC/MTC from PT and it works just fine. It nudges, scrubs and slaves in play-mode. So PT definitely fires the right MMC commands.
If Nuendo doesn´t follow it might be due to something on nuendo´s side (assuming that you have everything set tup correctly in PT). frank.
Scrub and video problem | Rikk | Pro Tools 11 | 4 | 09-17-2013 07:55 PM |
Video Satellite won't scrub | JLB | Post - Surround - Video | 1 | 07-22-2012 02:51 AM |
Slaving a video recorder/camera to PT HD transport? Recording synced video with audio | sonicam | Pro Tools TDM Systems (Mac) | 5 | 02-18-2010 08:39 AM |
Scrub audio and video | darkglass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-24-2005 06:16 PM |
Slaving PTLE Mbox to video deck | Pearl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-11-2002 11:06 AM |
