Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 05-01-2013, 08:14 AM
Jmmergens Jmmergens is offline
Default Multiband Compressors
Hi all,
Does anyone have a suggestions for a halfway decent RTAS muliband compressor freeware? I'm a hobiest so I don't want to spend too much money before I get a chance to experiment with multiband compression. If there isn't a good free multiband compressor (which seems to be the case from my searching) is it worth it to just get FX expansion and start wrapping the millions of free VST plug ins? Or do I really need to just suck it up and spend some extra money on RTAS plug ins?
Any advice is appreciated!
Thanks!
Old 05-01-2013, 10:27 AM
spenner spenner is offline
Default Re: Multiband Compressors
I haven't seen any free RTAS MB Comps.
Creating one is free and allows you to use any compressor and EQ you already have.
Old 05-01-2013, 11:54 AM
BohoProAudio BohoProAudio is offline
I use bus pass filters into compreesion all the time, especially for mastering. It can use up more of you processing power, but you generally get more control, plus you can do it with your favorite compressors instead of being limited to what multiband comps you have.
Old 05-01-2013, 01:32 PM
I'll give it a shot, thanks!
Old 05-01-2013, 04:19 PM
Good luck! I would say that unless you're mastering, or mix mastering, you won't need 4 bands. I usually stick with hi and lo pass, and that's enough for most sources. If you plan on getting deeper into mixing, you're going to want to invest in a good compression plugin sooner or later. By far the most useful and versatile type of plug that you will ever buy. I use McDSP's 6030, which has ten or so compressor plugins that work for almost any situation. If you want a good free(and very simple) pass filter EQ, try the Bluecat free plugin suite. Lots of good stuff in there.
multiband hardware compressors? musicman691 General Discussion 7 01-21-2014 12:54 PM
Multiband de-esser or Compressors? skylab001 Pro Tools TDM Systems (Mac) 4 04-28-2011 06:49 AM
Multiband Compressor danika Pro Tools M-Powered (Win) 9 07-11-2005 12:49 PM
Multiband compressors .... basic junior mastering Alécio Costa Tips & Tricks 1 07-26-2004 01:12 AM
Multiband Processors Punx Tips & Tricks 2 08-23-2002 01:22 AM
