Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 11-13-2012, 08:09 PM
hart07 hart07 is offline
Default Re: HD|N and system sounds...
Hello I am in the same situation with an I7 3930k +hd native+192I/o and dangerous monitor source
If I want to listen any cd or wave sound from my I7 its better to use the motherboard soundcard spdif output from my I7 to the dangerous monitor or the hd native driver and use the spdif output from my 192to the dangerous monitor sourceThks
Old 11-13-2012, 08:14 PM
have to use your mb spidf to your dangerous.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 11-14-2012, 11:21 AM
Ok the sound would be better with my mb spdif output to the dangerous?
Cause 192 output spdif got better converter?
Thks
Old 11-14-2012, 02:20 PM
Thks
there are no working drivers for the HDN for system sounds. have no option but to use your mb audio out.
pro-tools-pc.com
Intel I7 6800k
Win 10
Old 11-14-2012, 08:06 PM
Alternatively use an ASIO device and patch that back in.
Aaron Mulqueen - 001 HD Native
Old 11-16-2012, 05:25 AM
The hdn is not like a digi 003 with digi drivers working with Intel?
Before I was with my digi 003 under windows xp pro and I could listen any sounds from my Intel through the digi 003 factory
Actually I got the pro tools hd native with a 192 analog + digital card and a dangerous monitor source for monitoring and what would be the best solution to listen my cd and waves with my Intel?
Really spdif mb output to the dangerous spdif input? And not possible with the hdn through the 192 cause no working drivers?
Regards
Old 11-16-2012, 03:52 PM
Regards
No, there are no drivers Currently for your system to connect to the HDN. I would hope that is something that will be resolved at some point. Using the output of your soundcard or another asio device is necessary. Taking that spidf to your dangerous is the easiest since its just the push of a button to listen. Same thing I do on my system except w a central station.
pro-tools-pc.com
Intel I7 6800k
Win 10
Old 11-04-2013, 12:05 PM
Teolin Teolin is offline
Is running spdif out to Omni still a no go? Tried it and got a signal from MB into the Omni (channels 5-6), but couldn't get that signal to come out the monitors.
Is that a "driver issue?"
Pro Tools 12.4
HDN, PCIe, Omni & Digi 192
ASUS Sabertooth, Intel i7 3820 3.6Ghz
32 GB 1600Mhz Corsair RAM
SSD 500GB Samsung
WIN 10 64bit
HD|N and system sounds... danander11 Pro Tools HDX & HD Native Systems (Mac) 0 10-28-2012 05:24 AM
Pro TOols playback is OK, system sounds and other sounds won't play bimple Windows 1 08-24-2011 05:14 PM
System sounds & MBox robbins876 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-22-2003 12:00 AM
mix sounds different on a hi-fi system ChenteleyA Tips & Tricks 10 02-06-2003 10:23 AM
System sounds through 001? Rich_L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-13-2000 09:26 PM
