Yikes!! Ambience gone!!!
I upgraded to PT 9.0.6 the other day against my own better judgement as........whatever I had....9.0......9.01 or whatever, was working just fine with OS 10.6.4. I putzed around with it but did not notice anything that jumped out at me......I figured it was sort of a maintenance and fix type upgrade.
Well, I just opened a session for real and went to use Eleven Rack for a guitar part and only just noticed that the speaker ambience slider is completely missing from the speaker at the bottom of the amp interface. It used to reside to the right of the Bypass/On switch....in between the Digi logo and the Mic Type section. What gives? Has anyone else experienced this? Thanks.
Mac Studio M2 Max 12-core CPU, 38-core GPU, 16-core Neural Engine 64 GB memory 2TB Solid State Drive Thunderbolt 4 Sonoma 14.1.2 Pro Tools 2023.9 Universal Audio Apollo 8P (TB3 Option Card installed) |
Re: Yikes!! Ambience gone!!!
Just a guess. You have an Eleven Rack that has the ERXP. When you updated your Pro Tools version, it erased the updated UI files needed to display the ERXP items (speaker breakup was added by the ERXP) So, if I am correct, you need to re-run the first section of the ERXP, then discard the firmware updater that gets placed on your desktop. You can find the ERXP installer download from the Sticky in the guitar section or from the Eleven Rack Driver and Software Repository on my blog if you don't already have the installer on your hard drive. http://elevenrackusers.blogspot.com/...epository.html
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thanks Benoni, I am going to close this session and go check that out. Yeah...the speaker breakup..... I could not remember the name of it.
Hey man, you are a star!!!! I did the update from the link on your blog and all is healthy again.
Thank you friend! Oh BTW.....the blog looks awesome....I will spend some time there when I get a minute.
so you want more ambience in your overheads? | crizdee | Pro Tools TDM Systems (Mac) | 4 | 11-26-2008 02:10 AM |
ambience | manis | Post - Surround - Video | 2 | 09-01-2007 07:47 PM |
reverb on ambience | manis | Post - Surround - Video | 0 | 08-13-2007 06:22 PM |
recording Ambience in surround | feakerboo | Post - Surround - Video | 10 | 04-27-2007 08:28 PM |
How to remove ambience from a recording | psycho | Tips & Tricks | 2 | 12-07-2001 02:26 PM |
