#31
Re: How many samples delay can most people track with
NewdestinyX / Others ("We")
To achieve these low latencies while recording/tracking with PT, it’s necessary to leave Low Latency Monitoring (LLM) “OFF” (so the monitored tracks can be heard through PT and the “Playback Engine” (PE)). The mixer in the PE also has to be setup to monitor both the appropriate PT tracks and PE inputs. Automatic Delay Compensation (ADC) should be enabled so that the delays on all tracks are equal. Finally, PT 12.1’s new “Auto Input Monitoring Mode” should be selected for all of the record enabled punch-in tracks. If PT works right, everything should be properly synchronized in the recording and the performer(s) will only “hear” the (< 2 ms) DML. No plugins are bypassed and PT’s H/W Buffer Size(s) has no impact on the perceived latency (DML). So, it seems wise to maximize the Buffer Size(s) to maximize PT’s “stability”. I don’t really know how HD Native (and associated AVID hardware) works, but it appears that switches rather than mixers are likely used for LLM – is that right? HDX apparently does use mixers so, as long as no host plugins are used and none of the HDX plugins add delay to its monitored audio inputs, HDX reportedly should offer 0.7 ms DML. Unlike PT with modern third party interfaces, and apparently PT|HD Native with AVID interfaces, HDX may provide lower latency monitoring of “live” inputs going thru its own plugins. That’s really the only advantage I can see. 2015-07-15 Correction: HDX's advertised 0.7 ms DML is for a 96 kHz sample rate. In post #71 of the "Measuring Latency, Scarlett 6i6, DiGiGrid, etc." thread propower measured 0.47 ms with HD Native at 96 kHz and 1.9 ms at 44.1 kHz. So HDX at 44.1 kHz likely has more than 1.9 + (0.7 - 0.47) ms = 2.13 ms DML ("audible" tracking latency without plugins) with those AVID HD interfaces. Amack Last edited by Amack; 07-16-2015 at 12:29 PM. Reason: Correct HDX latency |
#32
You're wrong Amack. You can throw out all the numbers you wish it doesn't change the fact that it's not possible to monitor sub 2ms latency thru plugins using 3rd party interfaces.
The main part you're missing is that in non-HDX or non-Accel systems the ADC for the plugins you're trying to monitor while recording can't be compensated for without the additional latency they add. There are some plugins with minimal latency and that would help minimize anything added to your 'alleged' 1.86ms latency. But most plugins you would want add a lot more. So if you monitor with zero plugins - SOME interface out there capable of buffer 64 MAY get close WITHOUT plugins added - but after plugins - no WAY. Remember ADC can't compensate for plugins on a live recorded track.. in a non HDX/HD Accel system.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FSLast edited by NewdestinyX; 07-06-2015 at 05:39 AM. |
#33
NewdestinyX (Others),
I’m not sure if we disagree or agree. But the description provided in the new thread called “Low Latency Tracking without Pro Tools HD Native or HDX” might help us determine that! 2015-07-16 Update: The referenced thread was moved to the "Measuring Latency, Scarlett 6i6, DiGiGrid, etc." post#248 Amack Quote:
Last edited by Amack; 07-16-2015 at 12:16 PM. Reason: Provide updated info on thread |
#34
This topic is all very interesting and good to know, but why obsess over it? I'd rather spend my time making music...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#35
cwsand,
I'm just trying to understand DAW hardware/software capabilities, limitations, and usage so I can help my college student son succeed in the business - if he chooses to continue with that pursuit. Thanks for your patience and understanding as I do so! V.R. Amack |
#36
Samples delay on Reverb Aux track? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-11-2012 02:10 AM |
volume/peak/delay, delay shown in samples or ms? | Ziko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-29-2008 04:11 PM |
Delay samples | ricardo1073 | Tips & Tricks | 2 | 01-13-2008 10:28 AM |
System Delay by 3209 samples giving a 2 frame pre delay | tom.joyce | Post - Surround - Video | 8 | 05-17-2007 02:25 PM |
here u go people... a track if yr interested... | fabpab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-06-2003 07:09 AM |
