Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 06-05-2015, 10:54 AM
cwsand's Avatar
cwsand cwsand is offline
Default
I record at 48k since it's just easier if you're also working with video not to have to change the sample rate all the time. With most (if not all) 3rd party interfaces, you have to close Pro Tools to change the sample rate - a real PITA, especially since Pro Tools doesn't always boot right up recognizing the change.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.6
Old 06-05-2015, 11:01 AM
fredmant fredmant is offline
Default why i use 48k
Both my Eleven Rack and my Korg M3 run at 48k. I use SPdif connections for both to my RME Fireface 800. At 44.1K I get some error messages saying the 11Rack is at the wrong sample rate, and the M3 gets ticks from the clock mismatch.
If i ever actually finish a project, then I'll worry about dither
http://duc.avid.com/images/smilies/frown.gif
Old 06-05-2015, 11:06 AM
mesaone mesaone is offline
Default
You may want to start a thread about this, there's more to it than plugging in SPDIF. You've got to set things up so one device is the clock master, and the others are slaves.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 06-05-2015, 11:21 AM
Amack Amack is offline
Default
That's also true with Macs?
Old 06-05-2015, 11:39 AM
Default
There's an easier and more objective way to do this. See http://duc.avid.com/showthread.php?t=368473. Measuring it yourself is really the only sure way to determine your latencies. However, other DAWs do display the "Playback Engine" input and output latencies as reported by the interface's driver - which may or may not be correct)!
Originally Posted by albee1952 View Post
Given that HD has lower inherent latency, its probably going to be fine. Its pretty easy to test it out yourself(and I highly recommend everyone check it out). Slap on some phones, put up a mic with that same chain of plugins and give a listen. For most of us, this will reveal any "ugliness" in the time it takes to say "test one two"(I would recommend moving to 48K over 44.1K though)
  #16
Old 06-05-2015, 08:02 PM
cwsand's Avatar
Default Re: How many samples delay can most people track with
No - I just tested it and I can change it in Pro Tools, no problem. Really wish I could afford a Mac for my main DAW!
Help Us Help You
Chris
PreSonus Digimax LT
Pro Tools HD 2019.6
  #17
Old 06-06-2015, 09:49 AM
There's really no more objective a method than putting on headphones and trying it out in a real-life recording session. That tells me everything I need to know
  #18
Old 06-06-2015, 10:06 AM
Semantics I guess. Maybe I should have said "less subjective" or "quantifiable" instead of "objective"?
  #19
Old 06-06-2015, 10:09 AM
NewdestinyX NewdestinyX is offline
Default How many samples delay can most people track with
Same here! No math can ever tell me something more than my ears can.. Though I've noticed that for drummers , anything greater than a 2ms latency is unacceptable and they begin hearing flamming. A vocalist will hear a slight doubling at greater than 3-4ms. Instrumentalist can usually bear a little more.
PT HD thru HD hardware using AAX DSP plugin version will always be under 2ms of latency. Add some AAX Native plugins, then even w/HD hardware all bets are off. And if memory serves Low Latency Monitoring switch on Will defeat any plug-ins being run on a record input channel.
Not all ASIO drivers can take advantage of Low Latency Monitoring on nonHD interfaces either.. So you have to test by ear there too.
The standard of the pro industry is that you have to have sub 2ms latency to have latency be a non-issue for players. Hence why most pro rooms have PT HD + Avid Hardware.
Now 2 milliseconds… How many "samples" is that at 48K when you're looking at the delay compensation window? Somebody do the math for me..
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard
Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS
  #20
Old 06-06-2015, 10:34 AM
48K is 48,000 samples per second = 48 samples per millisecond (S/ms). 48 S/ms * 2 ms = 96 samples. How do you know how much latency you're getting with HD if you haven't measured it?
Samples delay on Reverb Aux track? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-11-2012 03:10 AM
volume/peak/delay, delay shown in samples or ms? Ziko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-29-2008 05:11 PM
Delay samples ricardo1073 Tips & Tricks 2 01-13-2008 11:28 AM
System Delay by 3209 samples giving a 2 frame pre delay tom.joyce Post - Surround - Video 8 05-17-2007 03:25 PM
here u go people... a track if yr interested... fabpab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-06-2003 08:09 AM
