Old 01-10-2012, 02:03 AM
JazzyJ JazzyJ is offline
Default Samples delay on Reverb Aux track?
HI,
I appreciate that if you have a vocal track and and insert a reverb plugin that causes sample delay, then you'd need to nudge the track in order to compensate for what the plugin on the insert is doing.
But,
How does it work if you've set up a Reverb on an Aux track with a 'send and return' using a Buss. The Reverb plugin shows the delay on the Aux track, obviously, as this is the track where the plugin has been inserted.
Do I still have to nudge my vocal track, or is it in some way different as it's the Aux track that has samples delay rather than the Audio track?
(Also, imagine it's a compressor and not a reverb - before I get replies about changing the reverb rate to compensate rather than how the system works!)
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 01-10-2012, 04:26 AM
GregV GregV is offline
Default Re: Samples delay on Reverb Aux track?
It depends on your "Mix" level in the plug-in. For example, typically a Reverb (or Delay) will be 100% Wet. So your Dry signal comes from the channel. That channel Sends to the Reverb. And the Aux Channel is Reverb only.
In which case, yes technically the Reverb may have some delay to it, but nudging ahead your Dry signal will cause it to be early.
If, however, it were a Compressor, there would be no Dry signal present. All of the Dry signal would go through the Compressor, and you would only listen to the post-effected signal. In which case, if there was some delay, you would nudge ahead the Dry track. This way, the processed signal would have the same (compensated) timing as the original Dry signal.
Did I understand your question correctly?
Does this help? (Probably not! haha) I hope it did...
Old 01-10-2012, 05:08 PM
Thanks.
I think I'm going to try and move to ADC in PT9 or 10 anyway.........
PT11 / OSX 10.8.5
Old 01-10-2012, 05:29 PM
Craig F Craig F is offline
most reverbs have a pre-delay setting, just lower that number a bit if it's to far out
(I find a 1/128th note to be a good pre-delay amount)
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 01-11-2012, 03:10 AM
Ben Jenssen's Avatar
Another way to do it is to route everything thru a aux before it goes to the master, and adjust the timing on that aux.
Not only reverbs but some other plugins have really large latency. Solution: The latent track directly to master, everything else thru the short delay on the aux.
volume/peak/delay, delay shown in samples or ms? Ziko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-29-2008 05:11 PM
Delay samples ricardo1073 Tips & Tricks 2 01-13-2008 11:28 AM
how many samples delay...? drivingmecrazy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-10-2007 05:55 AM
System Delay by 3209 samples giving a 2 frame pre delay tom.joyce Post - Surround - Video 8 05-17-2007 03:25 PM
Sounds like reverb or delay when recording another track jacksonusaplayer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-16-2007 04:32 PM
