Old 02-08-2021, 03:11 PM
tricyclerocks tricyclerocks is offline
Default Aae 9173
I recently installed Pro Tools 2020.12.0 on my Dell PC Windows 10
32 GB RAM Intel Core i5-10310U @1.7 GHz 2208 Mhz.
I constantly get freezes and the dreaded "Pro Tools ran out of CPU Power. Try De Activating or removing Native plugins (AAE-9173).
I have optimized my computer using Avid guidelines. I have reinstalled and updated everything I can find. I am not using anything intensive...one track of guitar and a few plugins. I tried deleting the click track.
I notice a huge spike in CPU for an instant when it freezes. It doesn't crash all the way...it just stops playing or recording at a random time.
Please help and much appreciated.
Old 02-08-2021, 03:32 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Aae 9173
Move all your plugins to unused folder and try again
Janne
Old 02-08-2021, 03:33 PM
Default Aae 9173
Old 02-08-2021, 03:48 PM
jeam25's Avatar
jeam25 jeam25 is offline
Hi !
When you say " optimized my computer " that includes the Bios settings ? On windows side anything related with CPU power saving or CPU stepping is a call for trouble. Double check that. If you have that set, please remove all your plugins installed temporary to the unsued plugins folder and test again. Also any external drive attached to the computer ?
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 02-08-2021, 05:02 PM
The Weed's Avatar
The Weed The Weed is offline
Run LatencyMon for 15 to 20 plus minutes and see if there is a driver causing interrupts to real time audio.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-08-2021, 05:43 PM
I ran Latency Mon. Says My system may be having trouble. I check the power throttling and it is DISABLED on PT (any everything).
I don't understand what a BIOS is.
Old 02-08-2021, 06:15 PM
ACPI Driver for NT make it go red.
I went into BIOS and got no where.
I Task Mgr and updated the drivers for ACPI Method Battery but they were up to date,
Old 02-08-2021, 07:13 PM
Hi & Thx.
I ran the Lat Mon and it spiked real quick.
I did more investigating and got into the BIOS (I think) and disabled as much of the Intel Boost things I saw, but none were exactly the same as listed on the internet. I also disabled all the Dell stuff at the start up...another suggestion. Now the Lat Mon says it still is "having difficulty" but it's all in the green. A little reddish "Highest reported DPC time" ACPI driver for NT.
I tried to go driver by driver to update but they all say they are current.
This, according to LatencyMon, has worked but the real test is when I run PT. Any other suggestions are completely welcomed, other than get a Mac.
Old 02-08-2021, 07:14 PM
Hi & Thx.
Old 02-08-2021, 11:35 PM
FunkzzaJ FunkzzaJ is offline
Try affinity settings.
With protools running:
Activity monitor > process tab > right click on protools > set affinity > uncheck lowest one or two cores.
/Fzz
Skickat från min Moto G (5) via Tapatalk
Free beer tomorrow !!
- but until then -
we're stuck in the present moment
9173, 9173, 9173... Hellooooo Rectifried Pro Tools 12 2 04-19-2018 12:50 AM
Dae 9173 danyg Pro Tools 2018 6 04-17-2018 04:04 PM
Aae -9173 frcjt Pro Tools 12 17 03-27-2016 08:09 PM
PT 12 - When 9173 is not actually 9173? taft_mashburn Pro Tools 12 2 10-06-2015 09:28 PM
Cpu 9173 mistermackum Pro Tools 11 1 12-20-2014 02:20 AM
