Midi from drums through command 8 then superior drummer
Hi Guys
just a little help is needed ive always used a midi uno for my digital drums midi info to travel to superior drummer in pro tools. never had a problem. Had to give the midi uno back to the chap i borrowed it off so i thought i use the midi ports on the back of my command 8. Can anyone out there help me set this up as im having no luck what so ever. Plus for some reason i cant get my command 8 to work with pro tools Thanks guys
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Midi from drums through command 8 then superior drummer
Is the Command8 working as a controller? Did you install the drivers for it(including midi drivers)? Are the ports available in the Midi Studio setup page? that page is the first place to look as you should setup your midi device(whatever you use the trigger).
Regards
Raoul Crane
Not sure as I don't have the Command 8. Did you look in the midi studio setup and see if the Command 8 midi ports are available? If they are, set them as the ports to use and test it.
New Toontrack video about using E-Drums with Superior Drummer | nst7 | The Drum Room | 0 | 11-20-2013 07:29 AM |
Best way to use VI Drums eg SSD4, Superior Drummer | Raoul23 | The Drum Room | 13 | 08-17-2012 10:04 PM |
Superior drummer or Steven slate drums | Raoul23 | The Drum Room | 20 | 01-27-2012 03:06 AM |
mapping superior drummer to drums | spidey01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-02-2008 09:10 AM |
Big [bleep] Drums, or Superior Drummer? | Peterjk | Virtual Instruments | 3 | 03-03-2006 11:04 PM |
