Setting Record Levels
O.K., so I've done my cartwheels and everything is set up, authorised etc.
Now it's time to study. I'm getting a delay between Xpand! and it's resultant audio when setting the record level, as well as when recording. I then have to drag the audio region into place afterwards. Is there a buffer setting that I need to check? Thanx!
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Re: Setting Record Levels
What are your buffer settings? You'll want to use the smallest buffer size possible to minimize latency (64 or 128).
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2 AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM www.wolfskinrecords.com www.voodoopilot.com |
Thanx for the reply. I went as far as 64 samples, but I got a message saying that I needed to increase buffer sizes; something about holding off interrupts for too long.
The range from 128 to 1024 produces the same sync problem. Actually, the delay is on the side of Xpand!, in that, the audio comes in a semi-quaver (sixteenth note?) before Xpand! plays , so I have to drag the audio to the right by that much. On close examination, the meters on the audio track actually move before those of Xpand! Any ideas? On another issue, and I'm sure this has been raised before. I remember seeing on a "wish list" where someone asked for "non-real time" bouncing, as per S***R, but can the same thing happen when "printing" audio from a soft synth, as in this case with Xpand!? It would seve time and greatly improve workflow. Thoughts?
Record enabled tracks, setting levels | LSW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-23-2006 08:05 PM |
Recording with a DI, setting the levels. | hmccabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-16-2003 12:31 AM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
setting record levels and adat bridge ... question | 5down1up | Tips & Tricks | 2 | 11-11-2001 09:36 PM |
Setting levels | CStern | Tips & Tricks | 0 | 02-02-2000 01:22 PM |
