did they ever sort out midi.....
did they ever sort out midi with XP and PT 5.3.1
i never have got the dam thing working... what should i do? any of u guys got it working? |
Re: did they ever sort out midi.....
Hello. What is the problem? Did you install the ASIO driver? Because that disables your Digidesign hardware MIDI ports, and they haven't released a bug free driver. Is this what you are referring to?
froyo |
THAT SUCKS!! THATS STUPID!!! Of corse i want to disable my midi ports when working with a unit that has midi ports... yes i have installed the ASIO driver.. i guess this be the problem then... i wont in futer... i can get most plugs to work through Logic anyway... |
fabpab...
I was searching for another Midi topic and saw this is only a few weeks old. I just wanted to tell you that you CAN access your Midi ports without that ASIO driver. I mean, if you just want to use your Midi device(s)(keyboard, drum machine, etc.) direct to the Digi ports, it works great. The ASIO driver disables them but allows you to use other programs with PTLE. Hopefully, PT6 will allow both Digi ports and ASIO to work, unless someone knows for sure otherwise... ~Roy
rh music |
Sort of a re-post! (midi woes) | ScottFB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-19-2007 06:00 PM |
Color Sort | hiroism | Tips & Tricks | 0 | 03-14-2007 10:50 AM |
S&M,,well sort of,, | Homebelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-11-2003 03:42 PM |
MIDI Sort Of Working...HELP | heybluez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-07-2001 08:52 AM |
what sort of FWB do I need | Steve Rosenthal | Storage Subsystems | 1 | 08-11-1999 12:58 AM |
