Old 11-02-2019, 11:06 AM
my-name-is-thanos my-name-is-thanos is offline
Default Latency
No matter what I do there's latency. I've tried everything. I'm running a guitar directly into scarlett 2i2. I'm then playing into a amp plugin on a mono audio track in Pro Tools 12, Windows 7. The plugin only actually works when I press the green I (Track Input Monitor). It won't let me record when Low Latency Monitoring is on... I don't know if delay compensation has anything to do with it. The 'direct monitor' switch is on on the interface. I've even tried to change the sample rate on Pro Tools.
Old 11-02-2019, 11:23 AM
amagras amagras is offline
Default Re: Latency
Sample Rate no bur buffer size might be.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
MIDI recorded latency after playing with no latency genebackmusic Pro Tools 12 8 01-19-2016 02:36 PM
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
