Disable Faders not working
Before Eucon 3.4 I was able to turn off the motors on my Artist Mix by pressing SHIFT + Solo (Channel 1). With 3.4 this function has disappeared. Has it been moved or is there a workaround?
I know there's a faders off function in Eucontrol but turning of the faders on the Artist Mix would leave the faders in the same position. "Faders off" brings all the faders down. I like turning off the faders when rearranging tracks when starting a new mix session. |
Re: Disable Faders not working
Yes they disabled that. It was in the release notes. I believe it is now a soft key command. Because the motors moving is extremely annoying I generally gravitate more toward using a Trim plugin on my last insert ( after all the other plugins )
You can do rides by accessing the trim plugin from the artist mix ( under inserts ) and then doing flip to fader and write all the volume automation on the plugin itself. |
Hello, I cant`t find this function in eucon software. I`m using artist mix with artist transport. In the manual they wrote "navigate the soft key editor to the global command options and choose FADERS OFF". But I can`t find global command options. Some help?
best regards |
disable faders on C/24 | jrecon | ICON & C|24 | 2 | 06-09-2008 08:26 AM |
No LED's working just faders | faxbear | ICON & C|24 | 1 | 04-10-2008 05:00 PM |
Disable moving faders during playback??? | Bryan Talbot | Pro Tools TDM Systems (Mac) | 5 | 02-25-2007 07:31 PM |
Qwerty Disable not working? | Don Geppert | ICON & C|24 | 9 | 01-29-2007 08:58 PM |
Disable moving faders | 1427 | ProControl, Control|24, Command|8 | 0 | 09-29-2003 06:09 AM |
