Old 02-21-2016, 04:34 PM
micheallsmith micheallsmith is offline
Default EuControl settings
Firstly, please forgive my lack of knowledge as I'm still pretty new to these products. I had my Artist Control, Mix and Transport set up and EuControl mapped for Adobe Audition (I spent hours customizing the keys to my workflow) and the computer that I was working on died. I purchased a new machine and was able to retrieve the files from the old one but was wondering if there was a way to copy the EuControl settings over from the old hard drive to the new one. I would hate to spend all that time again mapping everything out.
Dell XPS L702X
64 Bit
6 GB Ram
Windows 7 Home Premium
Old 02-25-2016, 12:47 AM
ALSTUDIOS ALSTUDIOS is offline
Default Re: EuControl settings
Originally Posted by micheallsmith View Post
....but was wondering if there was a way to copy the EuControl settings over from the old hard drive to the new one.
Hi
Refer to this article
http://avid.force.com/pkb/articles/e...ow_to/en413211
All layout-sets are stored in
Windows 7:
C:\Users\AppData\Roaming\Euphonix\UserSets\MC2User \MC_USER_SET__Root\...
Just take it from your "old" stored place and copy it into this folder on your new computer. This folder already exists, if you install the EuControl software - worked for me as well.
Cheers
ALSTUDIOS REGENSDORF SWITZERLAND
a.l.recordingstudio.ch@gmail.com
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win7 64Bit, Cubase Pro 10.0.20
Old 02-27-2016, 06:24 PM
Thanks so much! Unfortunately that file didn't survive the transition so I have to build it from scratch which has exposed another issue. I can't get any of the "Key" commands to work in EuControl. If I try to set up keyboard short cuts in Audition (example CTRL+SHIFT+D for Multitrack Mixdown) and then program a surface button on the control to activate that command, nothing happens. This method worked perfectly before I made the switch to a new machine (and updated version of EuControl). Has anyone else run into this problem with version 3.3.2?
Dell XPS L702X
64 Bit
6 GB Ram
Old 02-28-2016, 04:07 AM
I can't get any of the "Key" commands to work in EuControl. Has anyone else run into this problem with version 3.3.2?
Hi
There was a "big jump" in EuControl versions from v2.7.1 to v 3.2.2.
Unfortunately I must change to v.3.2.2 because Cubase PRO v. 8.xx does not support any EuControl versions below v 3.2.2. Therefore I changed by end of last year the EuControl software.
To answer your question
No.
There is no problem known by me with the key command in EuControl v3.2.2.
Works fine here.
Please make sure to work with the named tabs (Control) (ALT) etc. and don't "write" it by hand into the command line.
Cheers
Old 03-01-2016, 07:19 PM
Thanks for the response. I definitely used basic shift and control commands and nothing happened. I also didn't type it into the field...I used the preset commands that are in there. I may just uninstall it and reinstall it and see what happens.
Dell XPS L702X
64 Bit
6 GB Ram
What does EuControl W/S do? maunaloa Avid S1, S3, Dock and Control 10 06-19-2019 07:35 AM
Eucontrol & Cpu jky Artist Series 2 10-30-2016 10:38 AM
About EuControl 3.2 Marcel Risberg Artist Series 10 06-26-2014 05:18 PM
eucontrol settings Phili Artist Series 0 02-28-2012 04:31 AM
EuControl Trazan Artist Series 3 12-13-2011 01:57 PM
