Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 10-22-2014, 08:09 AM
NdimandeMpho NdimandeMpho is offline
Default missing iLok authorization with Pro Tools Express Akai Edition
Hi, please help. I bought the Axiom Air 46 midi keybored and it came with Pro tools express Akai Professional / M-audio Edition. I've registerd the ilok and re-installed pro tools but it keeps on telling me "Error, missing iLok authorization for Pro Tools Express. Please insert a necessary iLok and restart Pro Tools Express". What should I do now coz I've re-installed it three times already? I'm using Windows 7 ultimate
Old 10-22-2014, 08:33 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: ilok not authorizing?
Did you sync your ilok?
Does your device manager see your Ilok?
Daniel
Old 11-16-2014, 10:56 AM
Fidelitymusic Fidelitymusic is offline
Default Re: missing iLok authorization with Pro Tools Express Akai Edition
Has your Pro Tools Express license been activated on your iLok account? If so, have you then transferred it from your iLok account onto your iLok device?
When I received my Pro Tools Express my issue was that I never received a proper activation code. I had to contact Akai and have a proper activation code e-mailed to me. The new activation code allowed me to activate Pro Tools Express under my iLok username and from the iLok License Manager I transferred the license to my iLok device.
Old 01-05-2015, 11:49 PM
boatcristan2 boatcristan2 is offline
I was just about to post exactly the same problem, so I thought to mention it in this thread.
I went through the downloading of iLok licence manager v2.4.3 , have a second generation iLok in my USB port with the Pro Tools Akai Professional / M Audio Edition Primer product activated on the iLok.
Device Manager on the computer says iLok is installed (under dongles) with everything enabled.
I can xfer licences backwards and forwards from my iLok to my online iLok account. I can also synchronise the iLok with the online account.
Running the Pro Tools Express application however, gives exactly the error message indicated in this thread.
Is there any email address for Avid technical support to get this followed up ?
I have already reported the problem to iLok - here is their reply ..
Hello,
If a license that is on your iLok is not authorizing the associated software, please contact the software developer of the software you are attempting to use for further information on the use and authorization of their product.
Understand that the software developers are the only ones capable of licensing their products. PACE merely builds the infrastructure for the software publishers to distribute their products in the way that is consistent with their licensing terms.
iLok technical support
Old 01-06-2015, 12:03 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
The Primer is not the final license. You should have also received an Activation Code to register Pro Tools Express and deposit the full license on your iLok account.
Sticky: Pro Tools Express software - Start Here!
For help with Activation or Installation see the Pro Tools Express Installation Overview
Akai Professional & M-Audio Interfaces
Support and downloads for all of the Pro Tools Express software included with the InMusic Brands M-Audio and Akai interfaces is provided by InMusic, not by Avid. You can get downloads and help from their website here:
Installing and Authorizing Avid Pro Tools Express
www.inmusicbrands.com/ptex
Bruce Paine
System Details
Old 01-06-2015, 12:50 AM
OK..
So I have an Avid Pro tools Express Authorization code which when I go to the
Avid Software Activation and Download link page and enter my Authorization Code..I get the following message :-
We are sorry, but this code has already been used to activate software, and can only be used once.
If you have previously used this code to activate your product, please check your account for your downloads and codes.
If this is the first time you've used this code and it shows as already used, please contact customer support.
So - now I need to contact Avid customer support ..when no email address or any other contact method is given ...so we go around in a circle again ...
Old 01-06-2015, 06:23 PM
Admin Emeritus
In this case, because the Pro Tools Express software is sold and distributed by InMusic Brands, you would contact InMusic (Akai Professional or M-Audio support, depending on which product you purchased) for support and assistance:
Bruce Paine
System Details
Old 02-08-2015, 05:29 PM
Bruce...Yes - finally I got there....
After registering my M Audio M track Quad device I obtained a complimentary support code which I was then able to use to post a query to M Audio technical support regarding the problem I was having when I input the authorisation code contained on the Pro Tools Express card i.e. -
'We are sorry, but this code has already been used to activate software, and can only be used once'
Eventually, I received a response from inmusicbrands technical support regarding this support case who created a new authorisation code for me.
This time when I input the new code on the Avid Software Activation and Download link page I was then able to move on, surrender the primer licence and install the final licence on my iLok account, which was then subsequently transferred to the iLok usb device.
With the M Audio M Track Quad device attached I was then finally able to download the M Audio ASIO driver for the M track Quad device and then run Pro tools Express for the first time.
I notice however that you cannot run Pro Tools express without both the M Track Quad and iLok device being connected.
In addition, I don't seem to be able to find a way of configuring the Pro Tools Express software to use my normal Auzuntech sound system as a playback engine..the only selection available is the M audio M track Quad with ASIO driver.
Is it possible to allow the Pro Tools Express software to run without the M Track Quad connected ?
Old 02-24-2015, 10:05 AM
miguel.zamudio miguel.zamudio is offline
Default missing iLok authorization Pro Tools 10
Hello.
I can only work for 1 or 2 hours in pro tools. After that time the message that I have the iLok appears. And send my report to the people of iLok and its response was that it was going by a supposed failure to feed the iLok. They recommended me to wear a powered USB hub so I bought one and the problem persists.
This problem started when upgrading to the latest version of licencer manager.
error: missing ilok authorization for pro tools... please insert the necessary ilok. Witold.B Pro Tools Express on Mac OS X 1 04-21-2014 03:59 AM
Missing iLok authorization for Pro Tools 10 finalcut Windows 13 12-06-2013 11:50 PM
ilok missing authorization for pro tools mp9 Reggie TAE Pro Tools M-Powered (Mac) 0 11-15-2012 04:53 PM
error: missing ilok authorization for pro tools 9. please insert the necessary ilok.. weakluv Windows 2 07-07-2011 05:47 PM
missing ilok authorization for pro tools 9 monstaro Pro Tools 9 1 03-03-2011 02:45 AM
