Old 06-24-2013, 12:29 PM
Michael North's Avatar
Michael North Michael North is offline
Default "IO channel count for current playback"
Hi
I'm trying to get the demo of PT11
to run natively on a Mac Pro.
But ... On boot up the program gives me the following message:
"IO channel count for current playback device has changed.
Please restart Pro Tools."
So, I'm stuck and not sure what to do about it ...
Thanks
Old 06-25-2013, 07:43 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: "IO channel count for current playback"
I would change the playback engine at the splash screen
N during the PT11 splash screen - then select ur core audio
Daniel
Old 06-25-2013, 10:17 AM
Thanks !!
That was exactly it ...
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
Fix #1 for "Protools could not initialize the current playback device" jamesb1t macOS 1 06-13-2012 10:21 AM
"Protools could not initialize the current playback device" textiles Pro Tools 9 8 05-08-2012 09:33 AM
"The current playback engine does not support a sample rate of 48 KHz" E-Lister Windows 3 02-25-2012 11:54 AM
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 beasleymusic Pro Tools M-Powered (Win) 1 04-02-2011 03:17 PM
