Old 05-05-2015, 04:18 AM
Mark Ziebarth Mark Ziebarth is offline
Default Artist Control Firmware Update
I'm not sure if I should update firmware or not. I mainly use the Artist Control with a HD3 system and Pro Tools 10.3.9 (Mac OS 10.6.8) with EuControl 2.7.x.
But sometimes I want to connect it to a PT 11.3.1 HD system (Mac OS 10.10.2) with EuControl 3.2.2. This system requires a firmware update for the Artist Control to work.
My questions:
-Will the Artist Control on my main system work after the firmware update? Without updating components there?
-If not, which EuControl version is needed for PT HD 10.3.9? The current setup with all these old components works okay but not flawlessly. There is some fader jitter and Artist Control reboots are necessary sometimes. Would this improve if I update?
Any insights appreciated.
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 05-07-2015, 01:46 AM
Default Re: Artist Control Firmware Update
Anyone?
Old 05-08-2015, 04:13 AM
Seems like it's complicated. Do even the avid product specialists have no answer?
Best
Mark
Old 05-12-2015, 12:11 PM
I'm still waiting for an answer. Where else can I improve my knowledge?
It's an important decision for me.
Thanks
Mark
Old 05-12-2015, 09:51 PM
MoPro's Avatar
MoPro MoPro is offline
Thanks
Mark
I feel your pain brother!
You have a very specific set of parameters you've indicated that unfortunately don't apply to me... so, any info I give is based on my system which is PC Windows 7 64bit.
That said... I run the latest firmware in my Artist Controllers, but I run EuControl ver. 3.0.1.
This gives me the best flexibility with my setup, and I don't have fader jitter!
I also use Cubase Pro 8.0.10, and not Pro Tools!
The point I'm trying to make is that a little bit of experimentation may be in order for you to find out what is the best software/firmware combination for your setup!
I can tell you that there are trade-offs between the different versions of EuControl, and the latest version has broken functions that work properly in earlier versions!
Al
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 05-12-2015, 11:24 PM
Thanks, Al. You released me from the belief no one hears me…
Your answer leads me to the suggestion that the new firmware may work with my old EuControl for the 10.6.8 system. But a firmware upgrade is irrevocable, isn't it? That's why I'm in need for a reliable answer…
My question in short: Does a firmware upgrade of an Artist Control break the compatibility with EuControl 2.7.x?
Help, please.
Best
Mark
Old 05-13-2015, 06:32 AM
MoPro's Avatar
Mark
No... not at all! The firmware for the Artist Controllers is imbedded within each EuControl installer, and the firmware is then uploaded (by You!) to a flashable chip on the controller that can be flashed forward, or backward...how cool is that!
So, you could just install the version of EuControl that has the firmware version you are looking for... install the firmware, and then de-install that version of EuControl, so you can finally install the version of EuControl you need!
I know it sounds like a convoluted mess, but I also see the flexibility of having this operational scenario!
Whether you'll have issues relating to using a different firmware then what was imbedded within your installed version of EuControl is anyone's guess, but the backward compatibility will allow you to sync things up again if you need to!
Al
Old 05-13-2015, 06:42 AM
Thank you, Al. This helps a lot and gives me a understanding of how it works. I'll test it the other day…
Best
Mark
Old 05-13-2015, 08:36 AM
MoPro's Avatar
Thank you, Al.
You are very welcome... Good Luck!
Al
Help artist mix & control MacBook Pro Retina Update The software Alex Loop Artist Series 4 03-01-2013 11:47 AM
Firmware update on D Control SWSPHOENIX ICON & C|24 3 11-12-2009 11:51 AM
D-Control Firmware Reset/Update Brooklyn777 ICON & C|24 0 06-30-2009 10:55 AM
Control 24 Meters Off and Firmware update Re_Org ICON & C|24 3 03-11-2009 08:34 AM
D-Control Firmware update, touch-val not working real_eyes ICON & C|24 3 08-21-2008 03:03 PM
