#31
Re: How to go from Apple TV digital out to MTRX?
Doh. Well you could have said that more clearly
You could install Catalina and play Apple TV on your Mac... and because you can't run Pro Tools on Catalina you'll have more time to watch Apple TV. |
#32
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
#33
#34
So, how did you connected it? Can you test with a CD player SPDIF out? I mean, you said that you didn´t want to go analogue, to spare analogue ins on your MTRX, so I´m getting confused about what you wanna do....
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
#35
Not sure why you are confused, I'd like to save some of my analog inputs, but that doesn't mean I have none to spare at the moment. I'll have to get another analog card for the MTRX soon though.
To answer your question, the Apple TV HDMI goes to an HDMI Extractor. The coaxial digital output from the extractor goes to the Neutrik transformer, and from there to AES input 5 on the MTRX. It can't be clocked with just a single one-way connection, hence the problem. I supposed this might be possible if I wanted the master clock to be the Apple TV, but that would be crazy. Everything else in my system that's connected via AES and that have no work clock inputs (such as my Haken Continuum controller) need both AES in and out connected. Given this, I don't see how the Apple TV would be any different.
#36
Sorry it didn´t work for you. Just tried to help.If you were so sure of the outcome, why did you asked? Here´s some resources: https://www.rane.com/pdf/ranenotes/I...S3_&_SPDIF.pdf
#37
I wasn't sure of the outcome when I first asked (obviously!), but I'm sure now.
Thanks for your help...
#38
The fundamental principle in any digital connection (AES, MADI, etc.) between two devices is that the two devices must be synchronized to the same clock. If they are not synchronized, you will have clicks and drop-outs in the sound.
In this particular case, the Apple TV is the source and the MTRX is the receiving device. The Apple TV and the MTRX must therefore be synchronized to the same clock, otherwise there will be clicks in the sound. Since the Apple TV does not have a sync input (Word clock, AES input or similar), there is no way that the Apple TV and the MTRX can be synchronized. The only alternative to this is to use a sample rate converter (SRC) between the Apple TV and the MTRX. That way the Apple TV does not need to be synchronized to the MTRX. None of the devices that have been suggested in the thread have SRC, but are only format converters. My suggestion is to use an AES card in the MTRX. The AES card can do SRC on the inputs and it should therefore work fine. The AES inputs on the MTRX base unit do not have SRC so they can not be used. As the AES card is cheaper than an analog input card, you may want to go that way instead. If you do that, then please remember to order a break-out cable for the AES card as it has a special high-density connector. Alternatively you could maybe find a format converter with built-in SRC and the built-in AES.
Jan Lykke Business Development Manager DAD - Digital Audio Denmark |
#39
Are you suggesting MTRX cannot lock to external clock source? This scenario is simply playback from ATV not using it in a session...
#40
HD I/O with MTRX | Artis | Pro Tools | MTRX & MTRX Studio | 10 | 07-04-2019 10:01 AM |
MTRX and S6 | quadraphonics | Avid S4/S6 | 18 | 08-21-2018 06:12 PM |
MTRX Box | JSR | Avid S4/S6 | 4 | 11-01-2017 12:46 PM |
MTRX | antonis | Post - Surround - Video | 2 | 10-26-2016 12:31 AM |
Anyone been able to get 2 Apple digital monitors working? | EthanMorse | Pro Tools TDM Systems (Mac) | 0 | 11-06-2001 10:02 AM |
