Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 12-16-2018, 01:29 PM
Eric Lambert's Avatar
Default Eucontrol and Mojave?
From Avid:
While this software combination is unsupported, there is a simple workaround: Go to System Preferences > Security and Privacy > Privacy > Accessibility and enable EuControl.app under “Allow the apps below to control your computer”
I have tried this in System Prefs but the Eucon app still crashes at launch. PT 2018.12 and OS 10.14.2. Any ideas?
Old 12-17-2018, 08:28 AM
EddieJones's Avatar
Default Re: Eucontrol and Mojave?
What version of EUCON ? 18.3 ?
Run the installer again and choose to uninstall everything and remove all prefs. then reinstall and do the security pref thing again.
Old 12-17-2018, 09:35 AM
18.3
I uninstalled and reinstalled the app a couple of times without success.
I also use the iPad screensharing app Duet which also has access to the computer via the Security and Privacy pref. When I disabled that Eucon opened successfully.
Old 12-17-2018, 03:32 PM
To clarify, in case my situation isn't unique, I also updated Duet from some 1.x iteration to a 2.x version and Eucon and Duet now coexist. I don't know if this was fixed because I'd removed Duet then installed Eucon then reinstalled Duet, or if the newer version of Duet was the answer, but it makes sense that another app like that one which communicates with the iPad would be involved in the Eucon crash.
Mojave ? Riquier macOS 89 02-26-2019 07:41 PM
1st Mojave error mspin macOS 14 11-21-2018 06:15 AM
Mojave 10.14 install mspin macOS 6 09-26-2018 09:27 PM
Mojave Audio mic - anyone tried one? JSM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-08-2003 03:49 PM
