  #21
Old 04-20-2016, 11:56 AM
Reckless Erik Reckless Erik is offline
Default Re: X-form and pitch shifting
As someone said I believe the point about doing SRC first and then pitch shift, is to maintain phase coherence between channels, esp in muxed files. I tried Time Factory's SRC and found that channels drifted out of sync with each other. There is no sync drift if you do the SRC first on export from PT. The pitch shift in TF is very good with various different algorithms to suit tastes. It is also much faster than X-Form and is stand alone so you can continue working in PT whilst converting in TF (preferably on another pc as has also been mentioned).
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
  #22
Old 04-20-2016, 11:09 PM
lode lode is offline
If you "join" or whatever it is called (in TF) then the channels stay in sync.
When I have the time I´m going do try out the different methods including stems, whole mix, src-&-pitchshifting and timestretching.
Or has anybody else done a comparison before?
Newest Pro Tools on mac & pc.
  #23
Old 04-21-2016, 01:18 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default X-form and pitch shifting
Hi Garret
Elastique pitch looks very good from a quick scootch around. Very good price wise too.
Does it include an audiosuite version or do you have to run it live on stems and re-record the output?
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
  #24
Old 04-21-2016, 01:03 PM
garret garret is offline
Hi Mike. That's the only downside is that you have to run it real time. It has a long delay on it so you'll need long delay comp. no audio suite I'm afraid. Gives you a chance to check your mix on the way down one more time! ��
IMDB
  #25
Old 04-21-2016, 01:48 PM
Schottlandru Schottlandru is offline
I am not 100% sure but thought V2 contained an audio suite?
But I may be completely wrong here... just thought I kept reading it in the Audiosuite Menu.
(not in front of PT right now)
  #26
Old 04-22-2016, 02:12 AM
idris idris is offline
Just going back to the original question, any opions on the abilities of X-Form vs iZotope Radius / Time and Pitch / RX Advanced?
And any thoughts on the various parameters for different types of material? (eg Dx vs Mus?)
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
  #27
Old 04-22-2016, 03:19 AM
I am thinking of doing a test of the available products some time and publishing the results. It would make a very interesting comparison.
cheers
BAFTA member
IPS member
  #28
Old 04-22-2016, 06:33 AM
tom_lowe tom_lowe is offline
V2 is Audio Suite and running it as AAX has much much lower latency than V1. All round worthwhile, much nicer results than X-form.
  #29
Old 04-22-2016, 06:36 AM
Let me know if you want any help with test using Elastique, I'd gladly do anything to spread the word about this as I personally love it.
  #30
Old 04-22-2016, 06:54 AM
Tom can you confirm whether it has Audiosuite?
cheers
BAFTA member
IPS member
HTML code is On
Pitch shifting bontay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-15-2008 10:55 AM
Time shifting/pitch shifting? mistasmijen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2008 03:24 AM
Pitch Shifting danika 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2007 07:15 PM
Pitch Shifting Add - On SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2006 11:09 AM
25-24 fps pitch shifting. Does anyone know? Kenan Akkawi General Discussion 1 07-23-2001 04:10 AM
