Old 10-26-2020, 10:53 AM
doug kaufman doug kaufman is offline
Default Recent experience with new Mac Pro vs. HP PCs?
I'm due for an update on my primary system, which has been a trash can mac pro tethered to our Nexis system using Interplay Access as the check-in bridge between the Media Composer machines and Pro Tools machines.
I'm debating between purchasing a new Mac Pro or taking the leap to an Avid-qualified HP machine. I've tried to read up what I can, but I know there are always little quirks that I may not have considered yet. I did see that Catalina is not yet qualified with Interplay so that's definitely one factor.
Any experiences anyone has had in a similar environment with either machine would be appreciated!
dpkaufman.com
Old 10-26-2020, 11:12 AM
Brandonx1 Brandonx1 is offline
Default Re: Recent experience with new Mac Pro vs. HP PCs?
If you are used to OSX, windows might be frustrating. I use windows pro tools all day every day and really like it but I'm the odd duck and I have used both OSs extensively. If you are OK with windows, pro tools works great on windows. HP machines rock but are expensive. If you are used to the OSX modifier keys, you can modify windows to work like a mac's key commands.
Good luck
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 10-26-2020, 11:54 AM
If you run Dolby Atmos, then you will need to stay with Mac
Old 10-26-2020, 06:38 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
I've just gone from a MacPro 5.1 to a HP.
The notable stuff for me has been that the PC was unusable before I began optimising. It wouldn't even reliably record 1 track for more than 5 minutes with no plugins.
I got it to 16 tracks each with 5 Reverb One plugs recording for an hour at a 128 buffer (48k). It still has it's weird days, but so did my MacPro.
I remapped my mac keyboard because I didn't feel like learning the PC equivalents.
I lost the use of Source Nexus (Mac Only), and Source Connect is a bit more involved (you need to make sure you have a Source Connect 3.8 license because there is no 3.9 for PC).
There is no ADR software for PC that I've found.
PC ProTools looks ugly.
I have been getting serious graphics glitches, and will submit a bug report when I get some screen shots.
I'll probably go back to Mac once the dust has settled with the migration away from Intel.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT 2020.......
Old 10-27-2020, 07:05 AM
Pete Gates Pete Gates is offline
Without diverting this thread too much, what ADR software is missing for PCs? My software works on PC and so does EdiCue (there may be others too). Or is it streamers you are looking for?
Pete
Old 10-27-2020, 07:13 AM
paulo m's Avatar
paulo m paulo m is offline
That´s true if you use the DAPS, which is only available at the moment for MAC.
But if you have an external RMU running the Atmos Mastering suite, on a qualified MAC or PC, that´s not the case. Can use PT on a PC connected via Dante or MADI to the RMU.
Regards,
Paulo M
Old 10-27-2020, 07:16 PM
Pete
It's more the prompt/streamer side of things I was referring to Pete.
EdiCue shows as Win compatible for sure, but EdiPrompt lacks windows support at the moment.
I'm not a heavy ADR recorder so I was previously getting by with the cheap and simple "streamers" from figure43 (also Mac only).
Currently I'm baking streamers in with Resolve which is less than ideal.
ADR Master from NLA is Mac only.
VoiceQ is also Mac only.
Video Satellite as a workaround to slave a mac for video is unsupported when slaved to a PC....
That's as far I got before I decided to bake in my cues in frustration.
Cheers
Dave
Old 10-30-2020, 01:42 PM
I have done this for years and years with no issues. try it. It works fine or it used to 3 years ago.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 10-31-2020, 12:16 AM
Thanks for the heads up Brandon!
Old 11-02-2020, 09:50 AM
Kuba Pietrzak Kuba Pietrzak is offline
And this "ProTools on Mac" vs "ProTools on PC" thing is something, I cannot understand. And this is not only about 3rd party software. It is about ProTools on Windows itself. To me, it looks and works like it was poorly "ported" from MacOS, not written and coded for Windows from the scratch.
For music composition purposes I use Cubase, which works really IDENTICALLY, no matter on which OS it is run on. The only thing to remember is modifier keys, which is obvious. But in terms of stability, functionality and overall user experience, there is absolutely no difference.
As I understood, Nuendo also works the same on both Win and Mac.
My friends report, that besided other problems, the video playback quality is much worse on ProTools/Windows, even if a dedicated video hardware is used.
So - lots of issues to resolve.
best,
Kuba
HTML code is On
A recent experience involving hard drives... AlexLakis macOS 4 02-20-2015 11:14 AM
6.4.1 Mac and OMF from Recent Avids StefB Post - Surround - Video 4 11-04-2008 06:51 PM
What is the most recent version of Structure? Evil Jack Virtual Instruments 5 02-07-2008 06:28 PM
my most recent problems skwad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-06-2006 10:40 AM
Most Recent Version For OS 9? Rich Walsh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-14-2004 12:09 PM
