Old 01-05-2010, 07:00 AM
midnightrambler midnightrambler is offline
Default "Operation not CURRENTLY supported for conductor rulers"
Ten years I've been seeing this. TEN BLØØDY YEARS!!
http://img407.imageshack.us/img407/4833/picture2p.png
Isn't it about time the operation be supported digi? Hmmmmmm?
Old 01-06-2010, 12:19 PM
DigiTechSupt's Avatar
Default Re: "Operation not CURRENTLY supported for conductor rulers"
What are you trying to do, exactly?
Avid Audio Tech Support
Support FAQ
Old 01-06-2010, 03:32 PM
crizdee's Avatar
crizdee crizdee is offline
Change the song arrangement and have the marker locators ruler stick to their appropriate sections, like intro/verse/bridge/chorus etc. Drives me nuts when i'm trying to arrange a 10 minute mix and i want to quickly move sections around and try things and the markers can't move with everything else
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-06-2010, 04:24 PM
Mikey MTC Mikey MTC is offline
Totally agree. It's infuriating. Let's say you want to double your second chorus and therefore push everything else down the line. It takes almost no time to make the actual audio edit, but then you've got to manually move all the markers from that point onward forward.
Old 01-06-2010, 04:37 PM
Siegfried Meier Siegfried Meier is offline
Yep, this annoys the s•h•i•t outta me. I always wondered when it would be supported...
Old 01-06-2010, 04:38 PM
formfunction formfunction is offline
Well, it is a workaround.... i make the selection, then shift click the marker ruler, selecting that... then command-c. If I am working in Bars Beats, I just note the length (i.e. 8 bars, 16 bars...) of the section and then put the cursor where I want to insert this section. I then "insert time" there the exact same 8 bars (all the downstream markers shift 8 bars as well), and then paste the section I copied. All the markers move with the time insert and the paste preserves the ones copied.
I know this sounds complicated but it takes a few seconds once you get used to it... much quicker to do than explain. ff
Old 01-06-2010, 04:46 PM
Sean Russell Sean Russell is offline
Originally Posted by formfunction View Post
Well, it is a workaround.... i make the selection, then shift click the markers. then command-c. If I am working in Bars Beats, I just note the length (i.e. 8 bars, 16 bars...) of the section and then put the cursor where I want to insert this section. I then "insert time" there the exact same 8 bars (all the markers shift 8 bars as well), and then paste the section I copied. All the markers move with the time insert and the paste with shift click preserves the ones copied.
That's how I do it, too. PITA.
... but does it help the chorus?
Old 01-07-2010, 01:26 AM
crizdee's Avatar
Thats how i do it to! which is fine when you make a few obvious moves, but for song arranging its an absolute pain in the rear and way too messy to use insert/cut time for each move.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-07-2010, 02:19 AM
Mt.Everest Mt.Everest is offline
WOW. I was JUST yelling at my screen about this about an hour ago! I haven't tried to do this since PT 7.1 or something and tonight I was like hmm, lemme see if they finally added that long awaited feature. But NOOO! SAME MESSAGE!
Midnightrambler said it best! TEN F*&#king BL00DY YEARS!
Is it really that hard for Digi to make that change? Sure, the cut/copy/paste work-around is fine (but a PITA!) and I always get a little nervous when I cut a HUGE chunk, markers included, to paste somewhere else. It just psychologically sucks to see your entire screen EMPTY for those few seconds it takes to paste it where you want it moved. haha.
Seriously Digi (Avid, whatever) what is the holdup with this? I love how that message is just built into the software. I think its the only function that SAYS " you cant do this yet, sorry " as opposed to just not being able to do it. Its so frustrating to see that message for 10 years!
C'mmmon.. I just wanna be able to select my Verse and its markers and just slliiide it 8 bars sooner. Why do we still have to copy/cut and paste? Id love to know why this is such a difficult issue to improve.
DigiTechSupt? :)
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 01-07-2010, 10:13 AM
TLarvenz TLarvenz is offline
Seems like this would be an easy one to fix, unlike adding scoring notation (which I DO LOVE! Thank you!)...
Tracey
www.melodiousthunk.net
"operation interrupts" are cramping dbmystro macOS 1 12-16-2013 06:40 PM
"Operation not currently supported for Conductor Rulers? tmasten Post - Surround - Video 0 07-03-2013 01:48 PM
"this session contains media that is not supported by the video peripheral" samplaire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 08-25-2011 10:42 AM
New supported external drive "not a valid audio volume" j4callen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2009 08:53 PM
protools "performs illegal operation" when opening session nated 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-28-2002 06:20 PM
