ProControl connected and WORKING on ProTools 2018.7
First of all I have to say we have a miracle here.
***SPECIAL THANKS TO PAUL NEYRINCK*** V-Control Pro -> PC 32faders -> Protools 2018.7 Working like a charm. No delays, fast precise. 4 character scribble !? but hey it’s not that bad! DSP plugin edit and automation is now here. With their most up to date 2.2.19.1 version. Plugin Flip Mode *Requested*. Because I use this daily. Then i’ll Be in heaven. Can now upgrade to HDX with my beloved 32 channel / edit pack PC.
PT HDX2 / Ultimate / D-Command ES 24 w/ edit pack MP Dual 3.66mhz ( 6-Cores) / 32GB / SDD 8TB OSX Sierra 10.12 Dan Desilets Mix/Mastering Engineer, Guitarist, Composer New Website live @ www.yuccamusic.ca Last edited by Echo studios; 08-23-2018 at 04:54 AM. |
Re: ProControl connected and WORKING on ProTools 2018.7
When did this new update release with the DSP plugin edit and automation?
yes great update, thanks for the heads up and of course thanks Paul for making this possible
v2.2.19.1
PT HDX2 / Ultimate / D-Command ES 24 w/ edit pack MP Dual 3.66mhz ( 6-Cores) / 32GB / SDD 8TB OSX Sierra 10.12 Dan Desilets Mix/Mastering Engineer, Guitarist, Composer New Website live @ www.yuccamusic.ca |
Is this https://neyrinck.com/v-control-pro/ the site you're talking about? I can't find any info about the updates.
i didn't see any info either but download is there
Absolutely you fill in the form And download will start automatically If you scroll up the bottom of the page it says v2.2.19.1. This update has DSP edit enabled.
Same here : V CONTROL working like a charm (taking in count the limitations explained).
Even more functions are working than I expected, especially the PREVIEW and COMMIT PREVIEW shortcut in the ProControl are perfect and I use them all the time. So good!!!! And to reply to the choking silence from Avid for more than 3 years of people asking for such a solution for ProControl : my 200 dollars went to Neyrinck with a VERY GREAT PLEASURE to give them my money. It could have been yours, Avid, if you weren't so "short view" and had offered such a solution... I will soon upgrade to Ultimate (and Avid will have some of my money) so everybody has interest to make the ProControl working with PT 64bit (as EVERYBODY SAID in this forum). NOW, what about the "dead" Coreaudio for Accel/192 in PT 64 bit? Same stupidity from Avid! Working with my Reaper DAW, but not with your own DAW???? WTF I've solved the question buying an RME Fireface and it's PERFECT and much cheaper! 32 out is more than enough for my film mixing work. Won't get back to Avid hardware... One more time, Avid, open your eyes and be smarter than you've been up to now. |
Well if i could afford it i would gladly swap my pro control for an S6 :)
till that happens i'm happy that Paul saved us. |
ProTools 2018.3 wants to activate, but iLok is working fine | waynejones253 | Licensing & Accounts | 1 | 03-29-2018 07:53 PM |
S3L, keyboard & mouse not working when connected to surface. | voidmix | VENUE Live Sound Systems | 4 | 12-26-2016 01:57 AM |
MBOX PRO 3 A/D mode not working how do i know its connected | Martinrukshan | FireWire & USB Audio Interfaces (Mac) | 7 | 06-13-2016 05:16 AM |
Explaination of Procontrol working with Protools 11+ | drogan88 | ProControl, Control|24, Command|8 | 2 | 12-30-2011 02:39 PM |
Only first connected interface working - please help ! ;) | Ru_C | Pro Tools TDM Systems (Mac) | 6 | 04-02-2007 12:24 PM |
