What would be the best way to do this automation...
So Ive been experimenting with different techniques for volume automation. The technique I used in the past was volume pedal but most times I needed to tweak it anyway with the pencil.
So the question I have is what would be the best way to accomplish this using just write automation? To give you an idea of what I mean.... https://www.youtube.com/watch?v=SpkHmgnWx_U 0:20 The problem with writing automation of this kind in protools is it takes forever to get the groove right and that's the issue I have; the groove, and not being able to use a more specific grid to feed off. You can quantize notes to certain grooves but not automation nodes. What would be the best approach to this do you think?
Intel 6 Core i7-4930K CPU @ 3.40GHz 32GB DIMM DDR3 G.Skill Samsung SSD 840 EVO WD Black SATA 7200 ASUS SABERTOOTH X79 Windows 7 Ultimate 64 Mbox3 Pro Firewire 400 ProTools 10.3.8 ProTools 11.3.1 https://soundcloud.com/matthewcrowe |
Re: What would be the best way to do this automation...
Sounds like a compressor 'pumping'. Try a compressor sidechained off the Kick .Adjust the attack, release and threshold until you get the desired effect.
Yeah, I think it sounds like a pumping compressor too using the kick as the sidechain trigger. Of course, if you have the money to spend, the One Knob Pumper from Waves Audio is nifty little plug-in for only $80 bucks. One of the nice features on it is that you can set the timing and phase of the effect. Timing in meter, like 1/4 or 1/8 etc, and phase is 0, 90, 180, -90, -180. You can get some interesting rhythmic effects playing that. And the big knob is the equivalent of dry/wet. Its a great little tool for getting these kinds of effects.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Can't turn off capture automation on the automation panel | tandem | Post - Surround - Video | 0 | 07-16-2014 09:36 PM |
MIDI Automation to Audio Track Automation | BBKBB | Pro Tools 10 | 6 | 11-28-2012 01:56 PM |
Convert MIDI automation to audio automation | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2010 03:28 PM |
automation issues (re-writing automation when it shouldn't) | revere | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-13-2008 02:41 PM |
Automation Quirk...I didn't Write any Automation!! | a2zproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-20-2005 10:34 AM |
